2.13" e-ink Display Module for Raspberry Pi 4B/3B+/Zero W
$22.90
SKU: DFR0591
Purchase this product and earn 229 reward points, which are tied to VIP membership program. Learn More >
This Raspberry Pi e-ink display module comes with a 2.13" screen with a resolution of 250×122, adopting SPI interface to communicate with Raspberry Pi. It leads out the pins on Raspberry Pi, so there would be no conflicts if you need to use the e-ink display and Raspberry Pi’s pins at the same time. The display supports custom font. There are two patch touch switches on the module for expanding more applications. This e-ink display features small size, compact layout, plug and play, and low power consumption. It can provide clear display even in sunlight. When powered off, the e-ink display will continue to display the last screen. Since it will take a long time for the display to refresh fully, we don’t recommend using the product in the application that needs frequent refreshing to display data.
  • Operating Voltage: 3.3V
  • Resolution: 250 x 122
  • Interface Type: SPI
  • Color: black, white
  • Refresh Way: fully or partially refresh
  • Refresh Time: 3s for full refresh, 680ms for partial refresh
  • Refresh Power: 26.4mW(typ.)
  • Standby Power: 0.017mW
  • Visual Angle: >170°
  • Connector: 2.54mm 2*20pin
  • Dimension: 66.5 x 31 mm/2.62x1.22”
  • Storage Temp: -20℃~+60℃
  • Raspberry Pi e-ink Display Module x1
  • Double Nuts Copper x2
  • Screw x4
Damjan. Oct 28, 2022
Excellent e-ink display.
$22.90
