Gravity: Huskylens - An Easy-to-use AI Camera | Vision Sensor
$54.90
SKU: SEN0305
Purchase this product and earn 549 reward points, which are tied to VIP membership program. Learn More >
Huskylens is an easy-to-use AI Camera | Vision Sensor. DFrobot Huskylens is equipped with multiple functions, such as face recognition, object tracking, object recognition, line tracking, color recognition, and tag(QR code) recognition.
Through the UART / I2C port, HuskyLens can connect popular main control boards like Arduino, micro: bit, Raspberry Pi and LattePanda to help you make very creative projects without playing with complex algorithms.
Huskylens is pretty easy-to-use AI Camera. You can change various algorithms by pressing the function button. Click the learning button, Husky lens starts learning new things. After that, HuskyLens is able to recognize them.
Additionally, HuskyLens carries a 2.0 inch IPS screen. So you don’t need to use a PC in the parameters tuning. Enjoy the convenience it brings, what you see is what you get!
HuskyLens AI Camera is designed to be smart. It has the built-in machine learning technology that enables HuskyLens to recognize faces and objects. Moreover, by long-pressing the learning button, HuskyLens can continually learn new things even from different angles and in various ranges. The more it learns, the more accurate it is.
DFRobot Huskylens adopts the new generation of specialized AI chip Kendryte K210. The performance of this special AI chip is 1,000 times faster than that of the STM32H743 when running a neural network algorithm. With these excellent performances, it is capable of capturing even fast-moving objects.
With the HuskyLens, your projects have new ways to interact with you or the environment, such as interactive gesture control, autonomous robot, smart access control, and interactive toy. There are so many new applications for you to explore.
Huskylens' object-tracking skills can be used to learn specific gestures. It is able to recognize those learned hand movement patterns and feed their positions. With these data, creating awesome interactive projects are never so easy.
Huskylens vision sensor can detect and follow lines. Line follower is not something new, there are plenty of excellent methods and algorithms in this scenario. However, most of them require tedious parameters tuning. This time, HuskyLens provides a new way to do line following: simply click the button, then it starts learning and tracking new lines. Let's enjoy the fun of making with HuskyLens!
Husky lens machines can be the eyes of robots. which allows your robot to recognize you, understand your hand gesture commands, or help you put stuff in order, and so on. With Huskylens, nothing is impossible!
HuskyLens AI Vision Sensor Useful Functions
  • Processor: Kendryte K210
  • Image Sensor: OV2640 (2.0Megapixel Camera)
  • Supply Voltage: 3.3~5.0V
  • Current Consumption (TYP): 320mA@3.3V, 230mA@5.0V (face recognition mode; 80% backlight brightness; fill light off)
  • Connection Interface: UART, I2C
  • Display: 2.0-inch IPS screen with 320*240 resolution
  • Built-in Algorithms: Face Recognition, Object Tracking, Object Recognition, Line Tracking, Color Recognition, Tag Recognition
  • Dimension: 52mm * 44.5mm / 2.05 x 1.75inch
  • HuskyLens Mainboard x1
  • M3 Screws x6
  • M3 Nuts x6
  • Small Mounting Bracket x1
  • Heightening Bracket x1
  • Gravity 4-Pin Sensor Cable x1
 HuskyLens AI Vision Sensor – The Smart Camera for Your Robot Eyes | DF Robot
Projects HuskyLens AI Vision Sensor – The Smart Camera for Your Robot Eyes | DF Robot
Sayan Electronics
Apr 22, 2025
HUSKYLENS. Evaluación del dispositivo
Projects HUSKYLENS. Evaluación del dispositivo
José Manuel Ruiz
Feb 18, 2025
FlowGuard: Real-time Water Management with IoT and AI
Projects FlowGuard: Real-time Water Management with IoT and AI
Shebin Jose Jacob
Feb 18, 2025
Gun Away
Projects Gun Away
RoniBandini
Feb 18, 2025
Huskylens Playground with micro:bit
Course Huskylens Playground with micro:bit
Nov 27, 2024
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Steffen.Lorenz Jan 06, 2024
I had my first successes after just a few seconds! The product promise and my expectations were met. Development on macOS with Python also works perfectly. This little thing has real power and is fun to use. If you don't want to deal with models first but want to build on them straight away, this device is the perfect choice. I can really recommend it.
Thushara.Rathnayake Jul 03, 2021
What a lovely gadget . It is the best AI camera for a moving robot. I want to make out a real good project out of it soon
Case.Runner Apr 28, 2024
I only have one bad thing to say about it, and that is that it does not have physical documentation.However, I see why they may not bother. Other than that, its a really cool little gizmo. I look forward to finding more uses.
