Bluetooth 2.0 Bee Module For Arduino (Discontinued)
SKU: TEL0023
Discontinued
Note: Bluetooth 2.0 Bee Module For Arduino is discontinued now.
This DFRobot Bluetooth Bee Bluetooth wireless module adapts XBEE design. It has a compact size, the pinout is compatible with XBEE which is suitable for all kinds of microcontroller such as Arduino who have 3.3V power out, also the module supports AT commands for parameter setting. (NOTE: You have to use a XBEE adapter for parameter setting. )
The Bluetooth Bee modules comes with an on-board antenna, the antenna provides better signal quality. It acts like a transparent serial port, which works with a variety of Bluetooth adapter and Bluetooth phone.
The module has been tested with all the Bluetooth adapter on the market matching to use (with the Bluetooth, including laptops and mobile phones).
This arduino bluetooth module fits Gravity Arduino IO Expansion shield, Gravity Mega Sensor Shield, Romeo V2 and DFRduino Leonardo which has xbee socket
JavaScript display
Product Name Bluno Bee - Turn Arduino to a Bluetooth 4.0 (BLE) Ready Board
Bluetooth 2.0 Module V3 For Arduino
Bluno Link - A USB Bluetooth 4.0 (BLE) Dongle
Bluetooth Adapter Mini
SKU TEL0073
TEL0026
TEL0023
TEL0087
TEL0002
BLE Chip
 TI CC2540
CSR BC417143
CSR BC417143
 TI CC2540
Frequency
2.4GHz
2.4 ~ 2.48GHz unlicensed ISM band
2.4GHz
2.4 ~ 2.48GHz FHSS
Transfer rate
1Mbps GFSK
Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
1Mbps GFSK
3Mbps
BLE protocol
V4.0
V2.0 + EDR
V2.0 + EDR
V4.0
V2.0
Modulation
GFSK
GFSK
GFSK
GFSK
FHSS
Power consumption
10.6mA average, ready mode: 8.7mA
Sensitivity
-93dBm
≤-84dBm
≤-84dBm
-93dBm
≤-84dBm
Working Voltage 3.3V
+3.5 V ~ +8 V DC and 3.3V DC/50mA
3.3V
3.3V
Operating temperature
 -40 ℃ ~ +85 ℃
-20 ℃ ~ +55 ℃
-20 ℃ ~ +55 ℃
-10 ℃ ~ +85 ℃
-20℃ ~ +55℃
Transmission distance
30m
20 ~ 30m
20 ~ 30m
10 ~ 20m
<10m
Dimension
32*22mm
40*20*13mm
32*24*9mm
32mm * 16mm
20*16*8mm
Weight (g)
10
10
12
10
10
AT command to debug the BLE
master-salve machine switch
Transparent transmission
Wireless programming
√ (Available for Bluno series)
iBeacons
BLE HID
Mobile App Control
Key Featuressupport Android and IOS applications,open source code,suitable for secondary development by the user
Compatible with APC220 communication interface, can be directly used in I/O Expansion Shield, Romeo, XBoard and etc,.
It can be plugged into the Arduino controller using the XBEE base for Bluetooth wireless control.
Standard USB interface. Support for firmware update via USB. Install Arduino UNO USB driver, default host mode.
USB2.0 standard interface. supports the native Windows Bluetooth stack.
  • Bluetooth chip: CSR BC417143
  • Bluetooth protocol: Bluetooth Specification v2.0 + EDR
  • USB Protocol: USB v1.1/2.0
  • Operating frequency: 2.4 ~ 2.48GHz unlicensed ISM band
  • Modulation: GFSK (Gaussian Frequency Shift Keying)
  • Transmit Power: ≤ 4dBm, Class 2
  • Transmission distance: 20 ~ 30m in free space
  • Sensitivity: ≤-84dBm at 0.1% BER
  • Transfer rate: Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
  • Safety features: Authentication and encryption
  • Support profiles: Bluetooth serial port
  • Serial port settings: 1200 ~ 1382400 / N / 8 / 1
  • Baud rate default: 9600
  • Pair: 1234
  • Input Voltage: +3.3 DC/50mA
  • Operating temperature: -20 ℃ ~ +55 ℃
  • Module Size: 32 × 24 × 9mm (1.26 x 0.9 x 0.35in)
  • Bluetooth Bee x1
