A02YYUW Waterproof Ultrasonic Distance Sensor (3~450cm, UART, IP67)
$15.90
SKU: SEN0311
The sensor measures distance using ultrasonic pulses with high reliability, small blind zone, and wide angle. It's waterproof, dustproof, and ideal for harsh environments.
Purchase this product and earn 159 reward points, which are tied to VIP membership program. Learn More >
Ultrasonic distance sensor determines the distance to a target by measuring time lapses between the sending and receiving of the ultrasonic pulse. This is an easy-to-use commercial-grade ultrasonic sensor module of high performance and reliability, featuring much smaller blind zone, wider sensing angle and a certain penetration power(smog, dust) compared with other similar sensors .
Connection with Arduino
The ultrasonic sensor adopts closed separated probe, waterproof and dustproof, which could be well suitable for harsh and moist measuring environment. All the signal processing units are integrated inside the module, so users can directly obtain the distance value through Asynchronous Serial Interface. With 9600bit/s band rate, the sensor can easily communicate with upper-host or other MCU, which greatly shortens the developing cycle for users.
Connection with Raspberry Pi
Use the sensor with Arduino controller to build up your projects, such as backing car annunciator, obstacle avoidance robot, object approaching detection etc.
Beam Directionalities Diagram
Dimension Diagram
  • Accuracy: ±1cm
  • Operating Voltage: 3.3~5V
  • Average Current: <8mA
  • Blind Zone Distance: 3cm
  • Detecting Range(Flat object): 3-450cm
  • Output: UART
  • Response Time:100ms
  • Operating Temperature: -15~60℃
  • Storage Temperature: -25~80℃
  • Reference Angle: 60º
  • Waterproof Grade: IP67
  • A02YYUW Waterproof Ultrasonic Sensor x1
  • PH2.0-4P Connector x1
 How to Select the Ultrasonic Sensor
Blog How to Select the Ultrasonic Sensor
May 04, 2023
Automated Driveway Gates Version 2
Projects Automated Driveway Gates Version 2
KGray
Nov 01, 2022
TAKAO.SAKAMOTO May 31, 2025
Easy install to Raspberry Pi with pyhton.
I can use this by Python with Raspberri Pi 4 or CM5.
Mingkwunrak.Wonchana Feb 04, 2025
This product is a good quality product. You can see from the product itself that it uses good quality materials. The plastic looks good quality.
