Get the most out of your Raspberry Pi 4B with this high-quality aluminum case! Designed for Raspberry Pi 4 Model B, these cases are lightweight, durable and strong. Besides, the product offers a high heat conductivity and excellent corrosion resistance, which is able to better protect your Raspberry Pi board. The anodizing process performed on the surface of the metal greatly improves the quality of the case visually and tactually. All ports and slots of the case can match with Raspberry Pi 4 Model B perfectly. Meanwhile, there are mounting holes on the bottom designed for conveniently fixing the device on the wall.
Note: Raspberry Pi 4 Model B board is not included.
