This module employs the ESP32-D0WD chip of ESP32 series and also combines 2.4GHz WiFi and dual-mode Bluetooth. There are two CPU cores that can be individually controlled, and the CPU clock frequency is adjustable from 80MHz to 240 MHz. The user may also power off the CPU and make use of the low-power co-processor to constantly monitor the peripherals for changes or crossing thresholds. ESP32 integrates a rich set of peripherals, including capacitive touch sensors, Hall sensors, SD card interface, Ethernet, high-speed SPI, UART, I2C, and I2S.
The integration of Bluetooth, Bluetooth LE and WiFi ensures that a wide range of applications can be covered: using WiFi allows a large physical range and direct connection to the Internet through a WiFi router while using Bluetooth allows the user to conveniently connect to the phone or broadcast low energy beacons for its detection. The sleep current of the ESP32 chip is less than 5 µA, making it suitable for battery-powered and wearable electronics applications. The module supports a data rate of up to 150 Mbps, and 20 dBm output power at the antenna to ensure the widest physical range. As such the module does offer industry-leading specifications and the best performance for electronic integration, range, power consumption, and connectivity.
The operating system chosen for ESP32 is freeRTOS with LwIP; TLS 1.2 with hardware acceleration is built-in as well. Secure (encrypted) over the air (OTA) upgrade is also supported so that users can upgrade their products even after their release.
Dimension Diagram
