ESP32-WROVER-B Module (WiFi+Bluetooth 4.2, 4MB Flash+8MB PSRAM, PCB antenna)
$5.00
SKU: DFR0624
  • $4.85 3+ items
  • $4.75 5+ items
  • $4.60 10+ items
The ESP32-WROVER-B combines dual-core processing, WiFi 150Mbps, and Bluetooth 4.2 in a single FCC/CE-certified module. With 4MB Flash and 64Mbit PSRAM, it handles advanced applications like voice recognition and real-time sensor networks without external memory.
Dual-Core Performance for Demanding Tasks
Adjustable 80-240MHz clock speed enables parallel processing of WiFi data streaming and BLE beacon detection without lag.
Expanded Memory for Complex Applications
4MB SPI Flash + 64Mbit PSRAM supports MP3 decoding and high-speed data logging, eliminating crashes in memory-intensive projects.
Ultra-Low Power for Battery-Powered Devices
5µA deep sleep mode extends operational life by 3× compared to ESP8266, ideal for wearables and remote sensors.
Plug-and-Play Wireless Connectivity
Pre-certified PCB antenna (20dBm output) ensures stable 150Mbps WiFi range without RF design expertise.
Dimension Diagram of ESP32 WIFI+BLE Module
Dimension Diagram
Certifications
  • RF: FCC/CE-RED/IC/TELEC/KCC/SRRC/NCC
  • Bluetooth: BQB
  • Environmental: RoHS/REACH
  • Reliability Testing
  • HTOL, HTSL, uHAST, TCT, ESD
  • Wi-Fi
  • Protocols: 802.11 b/g/n (150Mbps max)
  • Features: A-MPDU/A-MSDU aggregation, 0.4μs guard interval
  • Frequency: 2.4–2.5 GHz
  • Bluetooth
  • Protocols: Bluetooth 4.2 BR/EDR + BLE
  • Radio:
          NZIF receiver (–97 dBm sensitivity)
          Class-1/2/3 transmitter with AFH
  • Audio: CVSD, SBC
  • Hardware
  • Interfaces: SD card, UART, SPI, SDIO, I2C, PWM, I2S, IR, GPIO, touch sensor, ADC, DAC
  • On-Chip Sensor: Hall sensor
  • Clock: 40 MHz crystal
  • Memory:
          4 MB SPI Flash
          8 MB PSRAM (Note: Corrected from "64Mbit" in intro)
  • Power:
          Voltage: 2.7–3.6V
          Min. Current: 500 mA
  • Operating Temp: –40°C to +85°C (Note: Adjusted to match datasheet standards)
  • Dimensions: 18.0±0.1 mm × 31.4±0.1 mm × 3.3±0.1 mm
  • ESP32 WIFI+BLE Module (PCB antenna) x1
  • ESP32-WROVER-B Module (WiFi+Bluetooth 4.2, 4MB Flash+8MB PSRAM, PCB antenna)
    $55.00
