Metal Case for NVIDIA Jetson Nano B01/A02/2GB
$25.90
SKU: FIT0645
  • $25.00 3+ items
  • $24.60 5+ items
  • $24.00 10+ items
This is a case designed for the Jetson Nano. Aluminum alloy, high-precision cutting and surface anode oxidation process, makes it quality in both visual and tactile. The housing retains the basic peripheral interfaces, which can connect peripherals such as mouse, keyboard and display directly. Besides, it supports the power switch and the reset switch, which is convenient for single-button start-up. An antenna interface is designed to make the wireless network connection more convenient. So that the antenna can be led from the internal.
Jetson Nano Case (Metal)
The housing retains the installation space for the GPIO hole and the fan. GPIO port and camera ribbon cable can be elicited by the gap reserved at the top. The case installation will not affect the use of camera and GPIO ports at all. The bottom also has a screw hole for easy fixation on the wall.
Most of the shell surface is designed with hollow, which can help the motherboard to dissipate heat better.
NOTE: This product does not contain a Jetson Nano board nor an antenna.
  • Compatibility: Jetson Nano A02/B01/2GB, Jetson Xavier NX
  • Material: aluminum alloy
  • Supporting the power switch and the reset switch
  • Convenient for single-button start-up
  • Dimension: 103*81*70mm / 4.06*3.19*2.76inch
  • Jetson Nano Case (Metal) x1
  • Switch x2
  • Screw pack x2
Only 19 Left
