4K Mini HDMI to Micro HDMI Cable for Raspberry Pi 4B
$4.90
SKU: FIT0649
This 4K HDMI cable supports stable, precise signal transmission for Raspberry Pi 4B and other devices. It's 80cm long, gold-plated, durable, and compatible with notebooks, HDTVs, tablets, and projectors.
This is a micro-mini HDMI video cable tailored to the Raspberry Pi 4B, supporting 4K HD resolution. There is no delay, no flash, the transmission is stable and precise. Plug and play, easy to connect.
A 19-core shield is adopted in this wire to ensure the stable transmission of the signal. A gold-plated process is used in the wire end interface which can prevent oxidation effectively and increase the durability. Multiple plug-ins will not affect its function. PVC environmentally friendly exterior makes it strong and soft, antioxidant and corrosion resisting. So, even through multiple bending, as always, remains stable signal transmission.
It is not only suitable for Raspberry Pi 4B, but compatible with a wide range of devices such as notebooks, HDTVs, tablets, and projectors.
  • Wire length: 80cm
  • Interface: micro-mini
  • Color: Black
  • Interface Material: gold-plated process
  • Supporting 4K transmission
  • Compatible with Raspberry Pi 4B, notebooks, HDTVs, tablets and projectors, etc
  • 4K Mini HDMI to Micro HDMI cable x1
  • 4K Mini HDMI to Micro HDMI Cable for Raspberry Pi 4B
