The RTC based on MEMS has already passed both shock tests and vibration tests that certified by ACE-Q100. It can withstand 2900g mechanical shock (JESD22-B104C Condition-H) and 20g variable frequency vibration (JESD22-B103B Condition-1).
The DS3231M can be powered by a coin cell battery and can still maintain accurate timing even the mains are disconnected. RTC provides information about seconds, minutes, hours, days, months, and years. It can automatically adjust the end date of the month and the leap year correction. The clock format can be 24 hours or 12 hours with AM/PM indication. It provides two programmable calendar alarms and one 1Hz square wave output. In addition, the RST check pin can be used as a key input for microprocessor reset.
Note: According to the latest Air Transport Regulations, the batteries, magnets and liquids transport will be very stringent, so the cell battery CR1220 will not come with the module any more. Please buy it from the local supermarket.
DS323X Selection Guide
Product Name |
Fermion: DS3231M MEMS
Precise RTC Module
Fermion: DS3231
Precision RTC Module
Fermion: DS3232
SKU | DFR0641 | DFR0819 | DFR0821 |
Storage | None | None | 236Byte |
Integrated Resonator | MEMS | XTAL | XTAL |
Timing Current | 2000nA | 840nA | 1500nA |
Timing Precision | ±5ppm (±0.432s/d) | ±3.5ppm (±0.3024s/d) | ±3.5ppm (±0.3024s/d) |
Operating Voltage | 3.3V-5.5V | 3.3V-5.5V | 3.3V-5.5V |
Operating Temperature | -45℃ ~ 85℃ | -40℃ ~ 85℃ | -40℃ ~ 85℃ |
Introduction | Integrated MEMS resonatr, reducing the risk of mechanical failure, suitable for use in strong and frequent vibration. | A RTC module with integrated crystal resonator, featuring a higher precision and a lower power consumption, suitable for use in the occasion in demand of high precision and low power. | A RTC module with integrated crystal resonator, equipped with 236Byte SRAM storage inside, enabling it to store data at an extremely low power consumption, suitable for low-power loT applications requiring real-time clock. |
