TF-Luna ToF Single-Point Ranging Solid State LiDAR Sensor (8m, UART / I2C)
$24.90
SKU: SEN0340
TF-Luna is a single-point ranging solid state Lidar, based on ToF principle. With unique optical and electrical design, it can achieve stable, accurate and highly sensitive range measurement.
Small Size Design
  • Small Size: 35mm*21.25mm*13.5mm
  • Light Weight: 5g
  • Low Power: ≤0.35W
  • ToF Single-Point Ranging Solid State LiDAR with Small Size Design
    High Performance & Economical
    This is a close-range, low-cost ToF single-point solid-state lidar with a range of 0.2m–8m. This solid-state lidar has high stability, high sensitivity, and high precision.
    Measuring Range of TF-Luna Solid State LiDAR: 0.2m ~ 8m
    Detection distance
    TF-Luna solid-state lidar's detection distance is up to 8m, the blind zone is 0.2m, and distance resolution is 1cm.
    Minimum edge length of 3.5 cm within a detection distance of 1m;
    Minimum edge length of 28 cm within a detection distance of 8m;
    TF-Luna Solid-State Lidar Sensor Detection distance
    TF-Luna Solid-State Lidar Sensor's relationship between effective length and detect distance
    Easy to get start, high level of generality
    The power supply voltage of TF-Luna lidar distance sensor is 5V, equipped with UART communication interface, the communication level is 3.3V. TF-Luna is compatible with Arduino, Raspberry Pi and other platforms.
    Wiring Diagram of TF-Luna ToF Single-Point Solid State LiDAR and Arduino Uno
    Wiring Diagram of TF-Luna Solid State LiDAR and Arduino Uno
    Wide Application Scenarios
  • Robot: Robot obstacle avoidance, Robot anti-drop protection
  • UAV: UAV obstacle avoidance, UAV altitude setting
  • Smart City: Smart toilets, Smart trash bins
  • Smart Retail: Smart ad trigger, Smart mirror trigger
  • TF-Luna ToF Single-Point LiDAR Applications
    TF-Luna is an economical solid-state lidar that is low-cost and can be widely applied to many development scenarios.
    TF-Luna applied to many development scenarios
    • Distance Resolution: 1cm
    • Frequency: 100Hz
    • Ambient Light Resistance: 70klux
    • Detecting Range: 0.2~8m
    • Weight: <5g
    • FoV: 2°
    • Supply Voltage: 5V±0.1V
    • Data Interface: UART/ I²C
    • Accuracy: ±6cm@(0.2m-3m)
  • TF-Luna LiDAR (8m) x1
  • Wiring x1
  • FAQ
    Gary Apr 06, 2023
    This can be very close to its rated indoor range outdoors. With a firmware update, you can even get it to work on I2C.
    Rob Smith May 18, 2022
    It is small, easy to connect and works very well. Can provide accurate measurements.
    Joshua. Mar 12, 2021
    These are fantastic modules! Function exactly as expected.
    $16.90
