Fermion: SHT30 Digital Temperature & Humidity Sensor (Breakout)
$6.90
SKU: SEN0330
  • $6.70 3+ items
  • $6.50 5+ items
  • $6.30 10+ items
Digital temperature and humidity sensor with SHT30 IC, supports I2C, compatible with 3.3V/5V controllers; ideal for smart home and IoT applications.
This Digital Temperature & Humidity Sensor Breakout Board is based upon the Sensirion SHT30 sensor IC. Thanks to Sensirion’s CMOSens® technology, highly integrated capacitive humidity sensing components and band-gap temperature sensing components, the SHT30 offers high reliability and long-term stability with low power consumption, fast response and strong anti-interference ability. The sensor supports I2C communication, and is compatible with 3.3V/5V controllers like Arduino, micro:bit, ESP32. It is easy to achieve precise and high-reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications.
SHT30 is the low-cost version of the SHT3x series. It provides humidity accuracy ± 2%RH@10% RH~90% RH (at 25°C), and temperature accuracy±0.2°C@0°C ~65°C (typical).
Digital Temperature and Humidity Sensor Selection Guide
Product Name SHT30 SHT31 SHT31-F SHT35
SKU SEN0330 SEN0331 SEN0332 SEN0333
IC Type SHT30-DIS-B SHT31-DIS-B SHT31-DIS-F SHT35-DIS-B
Typ. RH
Accuracy (%RH)
±2@10-90%RH ±2@0-100%RH ±2@0-100%RH ±1.5@0-80%RH
Typ.
Temperature (°C)
±0.2@0-65 ±0.2@0-90℃ ±0.2@0-90℃ ±0.1@20-60℃
Price $6.9 $8.9 $9.7 $16.9
Feature Cheap Cost-Effective IC Dustproof High Accuracy
  • High precise, internal auto-calibrated, digital output
  • Low power consumption, fast response, and strong anti-interference
  • Compatible with 3.3V/5V controllers
  • Urban Environmental Monitoring
  • Intelligent Building, Smart Home
  • Grain Storage
  • Plant and animal breeding system
  • Operating Voltage: 2.15~5.5V
  • Operating Current: <1.5mA
  • Humidity Detection Range: 0%RH~100%RH
  • Humidity Accuracy: ±2%RH@10%RH~90%RH(at 25℃)
  • Temperature Detection Range: -40℃~125℃
  • Temperature Accuracy: ±0.2℃@0℃-65℃(Typical)
  • Communication: I2C
  • Outline Dimension: 19x16mm/0.75x0.63”
  • Mounting Hole Size: 2mm/0.08”
  • Mounting Hole Pitch: 15mm/0.59”
  • DFRobot SHT30 Digital Temperature and Humidity Sensor x1
  • Black 2.54-6P Single Row x1
Blog Digital Temperature and Humidity Sensor Selection Guide
Apr 24, 2020
Out Of Stock
