Fermion: SHT31 Digital Temperature & Humidity Sensor (Breakout)
$8.90
SKU: SEN0331
  • $8.60 3+ items
  • $8.50 5+ items
  • $8.20 10+ items
This Digital Temperature & Humidity Sensor Breakout Board is based upon the Sensirion SHT31 sensor IC. Thanks to Sensirion’s CMOSens® technology, highly integrated capacitive humidity sensing components and band-gap temperature sensing components, the SHT31 offers high reliability and long-term stability with low power consumption, fast response and strong anti-interference ability. The sensor supports I2C communication, and is compatible with 3.3V/5V controllers like Arduino, micro:bit, ESP32. It is easy to achieve precise and high-reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications.
SHT31 is the standard version of the SHT3x series. It provides humidity accuracy ± 2%RH@0% RH~100% RH (at 25°C), and temperature accuracy±0.2°C@ 0°C ~90°C (typical).
Digital Temperature and Humidity Sensor Selection Guide
Product Name SHT30 SHT31 SHT31-F SHT35
SKU SEN0330 SEN0331 SEN0332 SEN0333
IC Type SHT30-DIS-B SHT31-DIS-B SHT31-DIS-F SHT35-DIS-B
Typ. RH
Accuracy (%RH)
±2@10-90%RH ±2@0-100%RH ±2@0-100%RH ±1.5@0-80%RH
Typ.
Temperature (°C)
±0.2@0-65 ±0.2@0-90℃ ±0.2@0-90℃ ±0.1@20-60℃
Price $6.9 $8.9 $9.7 $16.9
Feature Cheap Cost-Effective IC Dustproof High Accuracy
  • High precise, internal auto-calibrated, digital output
  • Low power consumption, fast response, and strong anti-interference
  • Compatible with 3.3V/5V controllers
  • Urban Environmental Monitoring
  • Intelligent Building, Smart Home
  • Grain Storage
  • Plant and animal breeding System
  • Operating Voltage: 2.15~5.5V
  • Operating Current: <1.5mA
  • Humidity Detection Range: 0%RH~100%RH
  • Humidity Accuracy: ±2%RH@0%RH~100%RH(at 25℃)
  • Temperature Detection Range: -40℃~125℃
  • Temperature Accuracy: ±0.2℃@0℃~90℃(Typical)
  • Communication: I2C
  • Outline Dimension: 19x16mm/0.75x0.63”
  • Mounting Hole Size: 2mm/0.08”
  • Mounting Hole Pitch: 15mm/0.59”
  • DFRobot SHT31 Digital Temperature and Humidity Sensor x1
  • Black 2.54-6P Single Row x1
How to Create an Indoor Temperature, Humidity, and Air Quality Monitoring System with ESP32-C6
Projects How to Create an Indoor Temperature, Humidity, and Air Quality Monitoring System with ESP32-C6
auroraAA
Jul 09, 2024
