Fermion: Monochrome 0.96" 128x64 I2C/SPI OLED Display (Breakout)
$14.50
SKU: DFR0650
  • $14.00 3+ items
  • $13.70 5+ items
  • $13.30 10+ items
Purchase this product and earn 145 reward points, which are tied to VIP membership program. Learn More >
This 0.96” OLED display module uses the SSD1306 drive chip, has 128x64 self-illuminating white pixels, and adopts two communication methods: SPI/ I2C, I2C in default. With its high contrast, simple wiring and low power consumption, it can be applied to many display applications, such as wearable display devices, Mini small game consoles, desktop widgets, etc.
This 0.96” OLED display module supports both 3.3V and 5V. The display module adopts a high-contrast, low-power OLED display. It is compatible with controllers such as Arduino UNO, Leonardo, ESP32/ESP8266, FireBettle-M0 and so on. Internal power-on reset processing, I2C communication methods, so that your welding line will be more convenient and simpler. If you want to change I2C communication to SPI, you just need to change the resistor position. In addition, the display is in an aluminum frame package that protects the screen from damage, and also prevents you from scratching that caused by the glass edge of the screen.
Note: Turn the pixels off when you are not using the display to prevent the use of some pixels too long to darken them, which will cause the brightness uniformity problem.
Monochrome I2C OLED Display Selection Guide
Product Name 0.91" 128x32 OLED-A 0.91" 128x32 OLED-B 0.96" 128x64 OLED
SKU DFR0647 DFR0648 DFR0650
Chip SSD1306 SSD1306 SSD1306
Voltage Input 3.3/5V 3.3/5V 3.3/5V
Resolution 128x32 128x32 128x64
Interface I2C I2C I2C/SPI
Welding Method Chip-mounting pad on the back Ordinary welding hole Ordinary welding hole
Size 41x12 mm 33x20 mm 30x30 mm
Price $9.90  $9.90  $14.50
 1. Small size, ultra-narrow design
 2. Display 2 rows of 16 pixel characters
 3. Chip-mounting pad
 1. Small size
 1. Display 4 rows of 16 pixel characters
 2. Support I2C/SPI
 3. Iron frame to protect the screen
Recommended  Suitable for users with certain hands-on ability to build up applications requiring space and appearance  Suitable for entry-level makers  Applicable for users who want to display  much content with high-speed SPI  refresh
  • Self-illuminating OLED display
  • Controllable pixels and low power consumption
  • I2C/SPI communication, I2C in default
  • Supports power-on reset
  • Thermometer
  • Desktop weather display
  • Kitchen weighing machine
  • Air quality detector
  • Mini Game consoles
  • Wearable display
  • Operating voltage: 3.3V to 5V
  • Color: white pixels
  • Number of pixels: 128 columns x 64 rows
  • Interface: I2C (in default) / SPI
  • I2C address: 0x3C
  • Drive chip: SSD1306
  • Brightness: 180 (Typ) cd/m2
  • Full-screen lighting power: approx. 24mA*3.3V/5V(I2C);
                                                        approx. 27mA*3.3V/5V(SPI)
  • Full-screen off power consumption: approx. 2mA*3.3V/5V(I2C);
        approx. 2.87mA*3.3V/5V(SPI)
  • Operating temperature: -30°C to 70°C
  • Display area: 21.744 x 10.864(mm) / 0.86”x 0.42”
  • Size: 30.00x30.00 mm / 1.18”x 1.18”
  • Weight: 4.2 g
  • Monochrome 0.96" 128x64 I2C/SPI OLED Display x1
  • 2.54 chip-mounting pin-6P x1
DIY A Simple Three-axis Accelerometer Data Logger
Projects DIY A Simple Three-axis Accelerometer Data Logger
Frances
Mar 02, 2023
The Millennium Falcon Audio Visualizer
Projects The Millennium Falcon Audio Visualizer
alankrantas
Feb 20, 2021
Blog Monochrome I2C OLED Display Selection Guide
Apr 26, 2020
KOUBELAN RICHARD.AKPAGNI Jul 13, 2023
This is a good product. I like
$14.50
