This cooling case is specially introduced to solve the heat problem of the Raspberry Pi 4B. The whole case is made of aluminum alloy, lightweight, and durable. It has excellent thermal conductivity and corrosion resistance, which can perfectly protect the mainboard. This case comes with two large cooling pillars inside that are close to the Raspberry Pi board. It can effectively transfer the temperature of the mainboard to the surface of the case for heat dissipation, which could reduce the temperature of the mainboard by about 10 ° C.
The surface of the case is made of aluminum alloy material with the oxidized sandblasting process to prevent the case from oxidizing and rusting, and for better heat dissipation, it is designed as regular bump instead of flat. With all ports and slots reserved for Raspberry Pi 4B, you can use this case with camera, CPIO, display and all other peripheral devices conveniently.
Note: Raspberry Pi 4B board is not included.
Oct 27, 2020
good product and shipping thank you
