Mecanum Wheel Kit (80mm - 4 Wheels)
$19.60
SKU: FIT0654-1
  • $19.00 3+ items
  • $18.60 5+ items
  • $18.00 10+ items
80mm Mecanum wheels allow omnidirectional movement with low noise. Made of plastic and silicone rubber, they feature 9 rollers and support up to 10kg.
Purchase this product and earn 196 reward points, which are tied to VIP membership program. Learn More >
Note: The kits include two pairs of Mecanum wheels (80mm): two left-handed wheels and two right-handed wheels. Please pay attention to the L and R noted on the back of the product when installing,
What wheels should your robot car use? How about Mecanum wheel! The Mecanum wheel is an omnidirectional wheel design for a land-based vehicle to move in any direction, such as go straight, obliquely, horizontally, S-line, and rotate at any angle with zero radius.
With pretty low noise, this kind of wheel can move stably and flexibly in operation. Since the wheel is based on the omnidirectional drive technology, users can freely control their robot car even in tight space. This Mecanum wheel has a diameter of 80mm and is composed of 9 small rollers that are made of plastic and coated with quality and high-friction silicone rubber, which are rugged and impact-resistant.
Dimension
  • Diameter: 80mm/3.15”
  • Thickness: 37.5mm/1.48”
  • Hex Hole: 7*7*7mm
  • Number of Rollers: 9
  • Angle: 45°
  • Load Capacity: 10kg
  • Color: yellow
  • Material: plastic + silicone rubber
