Gravity: Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C)
$53.90
SKU: SEN0322
  • $52.00 3+ items
  • $51.00 5+ items
  • $50.00 10+ items
Purchase this product and earn 539 reward points, which are tied to VIP membership program. Learn More >
This Oxygen / O2 Sensor is based on electrochemical principles and it can measure the ambient O2 concentration accurately and conveniently. With high anti-interference ability, high stablility and high sensitivity, this arduino-compatible oxygen / O2 sensor can be widely applied to fields like portable device, air quality monitoring device, and industries, mines, warehouses and other spaces where air is not easy to circulate.
This compact dfrobot oxygen / O2 sensor supports I2C output, it can be calibrated in the air, can accurately measure the oxygen concentration in the environmentit. It is compatible with many mainboards like Arduino Uno, esp32, Raspberry Pi and so on. Its measurement range is 0~25%Vol, and resolution can reach to 0.15%Vol. It supports wide range input voltage: 3.3V to 5.5V. Moreover, the lifetime is as long as 2 years. With simple Gravity interface and practical sample code, you can build your own oxygen / O2 concentration monitor easily and conveniently.
I2C Oxygen / O2 Sensor Selection Guide
Product Gravity:Electrochemical Oxygen / O2 Sensor  (0-25%Vol) - I2C
Gravity:Electrochemical Oxygen / O2 Sensor (Calibrated)
- I2C & UART
Gravity:Electrochemical Oxygen / O2 Sensor  (0-100%Vol) - I2C
SKU SEN0322 SEN0465 SEN0496
Detection
Range
0~25%Vol 0~25%Vol 0~100%Vol
Calibration
Method
Manual calibration Factory calibration Manual calibration
Output Signal I2C I2C、UART、Analog I2C
Working
Principle
Electrochemical Electrochemical Electrochemical
Stability <2%/Month <2%/Month <10%/Year
Response Time ≤15S ≤15S  0.1%~20.9%<40S  20.9%~100%<5S
Operating
Pressure Range
101kPa±10% 101kPa±10% 0.5 - 2.0 Bar
Temperature
Compensation
  • High sensitivity
  • I2C Interface
  • Compatible with both 3.3V and 5V micro-controllers
  • Polarity protection
  • Detection of Gas: oxygen / O2
  • Operating Voltage: 3.3 to 5.5V DC
  • Output Signal: I2C output
  • Measurement Range: 0~25%Vol
  • Maximum Measurement limit: 30%Vol
  • Resolution: 0.15%Vol
  • Sensitivity: (0.10±0.05) mA (in the air)
  • Stability: <2% (Every month)
  • Repeatability: <2%
  • Response Time: ≤15 seconds
  • Operating Temperature: -20~50℃
  • Operating humidity: 0~99%RH (no condensation)
  • Pressure Range: standard atmospheric pressure ±10%
  • Lifetime:> 2 years (in the air)
  • Dimension(L x W x H): 37 * 27 * 24.5 mm/1.46 * 1.06 * 0.97 inches
  • Weight:0.037kg
  • Gravity: Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C) *1
  • Gravity-4pin I2C Cable *1
  • M3*10 Nylon post *4
  • M3*5 Screws *8
    Niu.yx
    Feb 11, 2025
    Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Projects Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Qinchan.Wang
    Oct 16, 2023
    Explore how plants photosynthesize
    Projects Explore how plants photosynthesize
    Qinchan.Wang
    Oct 16, 2023
    Aug 10, 2023
