Gravity: IP65 Capacitive Soil Moisture Sensor for Arduino / ESP32 / Raspberry Pi
$14.90
SKU: SEN0308
  • $14.50 3+ items
  • $14.20 5+ items
  • $13.80 10+ items
The Gravity Capacitive Soil Moisture Sensor offers IP65 waterproof protection and corrosion resistance, designed for long-term outdoor gardening, automated irrigation systems, and environmental science projects. Using advanced capacitive sensing technology, it outperforms traditional resistive sensors with higher accuracy and durability in humid or wet soil. Compatible with Arduino, ESP32, and Raspberry Pi, this sensor ensures reliable moisture monitoring for optimal plant health in harsh outdoor conditions like balconies, gardens, and farms.
Gravity: Analog Waterproof Capacitive Soil Moisture Sensor
Fully Waterproof Design
The entire body of the sensor is waterproof, allowing it to be fully submerged in water without any performance degradation. This ensures reliable operation in outdoor gardens, greenhouses, and potted plants where exposure to water and humidity is frequent. Whether used in heavy rain or constant irrigation, the sensor continues to deliver accurate readings.
Corrosion-Resistant and Durable
Designed with longevity in mind, the sensor's capacitive measurement principle eliminates the corrosion risks common in traditional resistive sensors. The robust construction prevents the sensor from wearing down even when left in soil for extended periods, reducing the need for frequent replacements. Its scratch-resistant surface further enhances durability, making it perfect for long-term use in harsh environments.
  • Supply Voltage: 3.3 ~ 5.5VDC
  • Interface: 2.54-3Pin
  • Output Voltage: 0 ~ 3VDC
  • Cable Length: 1.5m
  • Dimension (L x W) : 175 x 30mm / 6.89 x 1.18 inches
  • Analog Waterproof Soil Moisture Sensor *1
  • Waterproof Label *4
    Jan 13, 2025
    Guillaume.Boucher Jun 26, 2024
    Working way better than the other ones that rust within a few weeks.
    pananya.somwong Dec 18, 2021
    Very Good Product
    Chih.Kuo Nov 24, 2021
    works fine
    $269.00
