This URM12 from DFRobot is a long range ultrasonic distance sensor designed for distance ranging or obstacle avoidance applications. The sensor offers up to 1500cm detection distance, 3Hz measuring frequency and 15° detection angle. It adopts RS485 communication interface and supports standard Modbus-RTU communication protocol, which is suitable for level measurement, robot obstacle avoidance and so on.
URM12 Beam Angle
DFRobot Ultrasonic Sensor Selection Guide
Product Name | URM37 Ultrasonic Sensor | URM06-RS485 Ultrasonic Sensor | URM06-UART Ultrasonic Sensor | URM06-PULSE Ultrasonic Sensor | URM06-ANALOG Ultrasonic Sensor |
SKU | SEN0001 | SEN0149 | SEN0150 | SEN0151 | SEN0152 |
Image |
Structure | Open Divided Send and Receive | Open United Send and Receive | Open United Send and Receive | Open United Send and Receive | Open United Send and Receive |
IP Grade | NO | NO | NO | NO | NO |
Working Temperature | -10℃~+70℃ | -10℃~+70℃ | -10℃~+70℃ | -10℃~+70℃ | -10℃~+70℃ |
Operating Voltage | DC 3.3~5.5V | DC 6~12V | DC 6~12V | DC 6~12V | DC 6~12V |
Acoustics Degree | 60° | 15° | 15° | 15° | 15° |
Acoustics Frequency | 40KHZ | 50KHZ | 50KHZ | 50KHZ | 50KHZ |
Range | 2cm~800cm | 20cm~1000cm | 20cm~1000cm | 20cm~1000cm | 20cm~1000cm |
Resolution | 1cm | 1cm | 1cm | 1cm | 1cm |
Deviation | 1% | 1% | 1% | 1% | 1% |
Sensitivity Level | 5 | 5 | 5 | 5 | 5 |
Communication Interface | RS232/UART/ANALOG | RS485 | UART | PULSE | ANALOG |
Features |
Multi-interface integration;
Automatic gain adjustment;
Automatic control of ranging;
Corrosion-resistant PVC housing;
Screw-free wiring port;
Narrow beam class linear directional detection;
Applications |
Education robot omnidirectional obstacle ranging;
Underground parking space monitoring;
High-voltage line-to-ground barrier avoidance;
Narrow space obstacle detection |
Product Name |
URM07-UART Ultrasonic Sensor |
URM08-RS485 Ultrasonic Sensor |
URM09-I2C Ultrasonic Sensor |
URM09-ANALOG Ultrasonic Sensor |
URM12 Ultrasonic Sensor |
SKU | SEN0153 | SEN0246 | SEN0304 | SEN0307 | SEN0310 |
Image |
Structure | Open United Send and Receive | Closed United Send and Receive | Open Divided Send and Receive | Open Divided Send and Receive | Closed United Send and Receive |
IP Grade | NO | IP65 | NO | NO | IP65 |
Operating Voltage | DC 3.3~5.5V | DC 6~12V | DC 3.3~5.5V | DC 3.3~5.5V | DC 9~24V |
Acoustics Degree | 60° | 60° | 60° | 60° | 15° |
Acoustics Frequency | 40KHZ | 40KHZ | 40KHZ | 40KHZ | 40KHZ |
Range | 20cm~750cm | 35cm~550cm | 2cm~500cm | 2cm~500cm | 70cm~1500cm |
Sensitivity Level | 3 | 6 | 4 | 4 | 6 |
Communication Interface | UART | RS485 | I2C | ANALOG | RS485 |
Features |
Ultra-low power consumption;
Small, streamlined design;
High sensitivity large area detection;
Full structure shielding;
Real-time calibration over the operating temperature range;
Efficient I2C communication mode;
Configurable detection range;
Analog voltage output;
No need to control, plug and play;
Automatic measurement, real-time output;
Large reliable detection range;
All-round protection design;
Corrosion-resistant and anti-pollution ABS materials;
Narrow beam linear directional detection;
Applications |
Aircraft height; Indoor IoT Devices; Line product counting; |
Collision prevention of industrial transport facilities; Unattended guards; Anti-theft alert; |
Robotics education; Indoor robot assisted barrier avoidance; |
River water level detection; Chemical tank level detection; |
