Fermion: 2.0" 320x240 IPS TFT LCD Display with MicroSD Card (Breakout)
$17.90
SKU: DFR0664
  • $17.30 3+ items
  • $17.00 5+ items
  • $16.50 10+ items
2.0" LCD with ST7789V chip and 320*240 pixels, supports SPI communication, GDI port, 3.3V-5V power, onboard MicroSD slot, and wide viewing angle.
This 2.0” LCD display adopts ST7789V driver chip and has 320*240 color pixels (RGB565), performing excellently in the angle of view (80/80/80/80). It supports SPI(4-wire) communication mode and GDI port (work with main-controllers with GDI), plug, and play. The module can be powered by 3.3V~5V, compatible with multiple main-controllers like Arduino UNO, Leonardo, ESP32, ESP8266, FireBeetle M0, and so on. Use the GDI interface to work with M0, which could effectively reduce wiring steps. Besides, there is an onboard MicroSD card slot for displaying more pictures.
The module has the advantages of high resolution, wide viewing angle, and simple wiring, and can be used in many display applications: waveform monitor display, electronic gift box, electronic weather decorations, etc.
NOTE: MicroSD Card is not included, click here to buy one.
  • Wide-angle of view
  • High resolution
  • GDI interface: plug and play
  • Onboard MicroSD card slot
  • Waveform monitor display
  • Electronic gift box
  • Electronic weather decorations
  • Alarm clock display
  • Operating Voltage: 3.3V-5.5V
  • Color Depth: 16-bit (RGB565)
  • Pixels: 240 x 320
  • Communication: SPI
  • Brightness(cd/m2): 250 (TYP) cd/m2
  • Full-screen Consumption: about 29mA (3.3V)/ 29mA (5V)(Typ)
  • Operating Temperature: -30℃~+70℃
  • Display Dimension: 1.20 x1.61inch / 30.6 x 40.8 mm
  • Module Dimension: 1.41x2.36inch / 35.70 x 60.00 mm
  • Mount Hole Diameter: 2mm
  • Weight:26g
  • 2.0" 320x240 IPS TFT LCD Display with MicroSD Card Breakout x1
  • 2.54-10P Single Row Black Pin x1
  • FPC0.5-18PIN Flex Flat Cable Reverse Direction 10cm x1
    Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    Projects Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    RoniBandini
    Aug 05, 2024
    Making a Amazing Tool with Arduino | Arduino Projects
    Tutorial Making a Amazing Tool with Arduino | Arduino Projects
    The Wrench
    Feb 15, 2024
    Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Projects Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Kutluhan Aktar
    Feb 09, 2024
