1700+ SKUs! 30% Off First Item + Free Shipping ($100+) ➡️ Shop Now
Aluminum Case for Raspberry Pi 4 (with Heatsink & Fan)
30% OFF FOR FIRST UNIT
$6.50
SKU: FIT0697
An aluminum thermal case enhances Raspberry Pi 4 cooling with efficient heat dissipation and simple installation. It supports unobstructed WiFi/Bluetooth signals.
15 th
First-unit discount applied automatically at checkout after login.
Purchase this product and earn 65 reward points, which are tied to VIP membership program. Learn More >
Keep your Raspberry Pi 4 cool and running smoothly with a thermal case. This aluminum-made case features hollow design, delicate appearance, and high hardness. The aluminum material makes it not easy to rust and more conducive to heat dissipation.
The main-board socket is integrated on the lower cover, and the upper cover is only fastened by one screw, so the installation could be quite simple. Only a few steps installation, your Raspberry Pi 4 can maintain a very stable performance all the time in using! If you just wanna buy a case for your Raspberry Pi 4 board, this cost-efficient one is worth trying.
Accurate Hole Position
The hole design of the housing corresponds to the interface position of the Raspberry Pi motherboard. Perfectly fit the Raspberry Pi 4 board, no gaps left.
Aluminum Alloy Material
High hardness, metallic luster, not easy to rust, more conducive to heat dissipation.
Double Cooling Effect with Fan & Heatsink
The hollow design makes it more effective in heat dissipation, protecting your motherboard in all directions.
No Effect on WIFI/Bluetooth
The aluminum alloy case is an open design, which will not affect WIFI/Bluetooth signal transmission at all.
  • Fan voltage: 5V
  • Material: Aluminum alloy
  • Dimension: 94*61*32mm/3.7*2.4*1.26”
  • Aluminum Case for Raspberry Pi 4 (with Heatsink & Fan) x1
  • Cooling Fan x1
  • Heatsink x3
  • Accessories Package x1
  • Review
    KOUBELAN RICHARD.AKPAGNI Sep 20, 2023
    Great, very nice product
    KOUBELAN RICHARD.AKPAGNI Sep 13, 2023
    Very nice. It's sustainable.
    Reijo.Korhonen Jul 19, 2023
    Case and heatsinks are OK, but fan is not usable, because proper fan needs control and control needs electricity and 3 wires. This fan fan only 2 wires for 5V and GND so it is always running and it makes sound. Most users don't need fan, so let it be in the box.
    Only 3 Left
