Armor Case With Fan(3510) for Raspberry Pi 4B
$18.90
SKU: FIT0714
Rigid Armor protective case with super heat dissipation!
This new aluminum case is capable of providing a better cooling solution for your Raspberry Pi 4B. Meanwhile, it can be access to all ports and slots of Pi 4B module.
The thermal pads cover all the heat-generating components except the wireless chip. And they align with the heat sink perfectly to achieve better heat dissipation.
Two 2510 fan has a stronger cooling performance and can work very quietly.
This case has an acrylic window on the side that helps in improving Wi-Fi/Bluetooth performance and makes status lights visible. It also provides Micro-SD card access and camera cable pass-through.
Connection with two Fan:
  • Rigid armor case
  • Aluminum body
  • Acrylic side plate for better wireless signal strength
  • Excellent cooling effect
  • NC machining
  • Two 2510 fans
  • Easy to install
  • Dimension: 10.8 x 7.6 x 3.8cm
  • Weight: 200g
  • Armor Case With Two Fan(2510) for Raspberry Pi 4B x1
  • Thermal silicon pad x4
  • User Manual x1
  • Only 7 Left
    $54.90
