Button-Adjustable IR Proximity Sensor with Real-Time Feedback (0-200cm)
$12.90
SKU: SEN0381
  • $12.60 3+ items
  • $12.40 5+ items
  • $12.00 10+ items
This digital IR proximity sensor detects objects up to 200cm and features adjustable distance, button control, and real-time feedback, ideal for smart home applications.
Featuring an innovative button-adjustment system, this IR sensor allows field calibration without tools - press to set 0-200cm detection while the LED status indicator shows real-time operation. The 30° narrow detection cone minimizes false triggers in cluttered environments like warehouse robotics. With IP67 waterproofing and -20℃ cold resistance, it's built for outdoor smart mailboxes and agricultural drone navigation.
The sensor is based on the principle of diffuse reflection of IR light on objects. When a person or object enters the sensing range in front of the sensor, the sensor immediately determines that there is induction, so as to control the output signal; after the person or object leaves the sensing range, it will judge that there is no induction, and stop signal output, by which intelligent control can be achieved.
Digital IR Proximity Sensor(0-200cm)
  • Wide range of applications
  • Onboard button for detection distance adjustment
    • Power Supply: 5V
    • Detection Distance: 0–200cm (adjustable)
    • Output: switch quantity (active-high)
    • Detection Angle: 30-40°coning angle
    • Detection Mode: active
    • Operating Temperature: -10~60°C
    • Storage Temperature: -20°~70°C
    • Waterproof Performance: IP67
  • Digital IR Proximity Sensor (0-200cm) x1
  • Button-Adjustable IR Proximity Sensor with Real-Time Feedback (0-200cm)
    $19.90
