Gravity: AS7341 11-Channel Visible Light Sensor
$17.50
SKU: SEN0364
  • $16.90 3+ items
  • $16.60 5+ items
  • $16.10 10+ items
11-channel sensor detects visible and near-IR light, ambient flicker, and enables high accuracy color detection, mixing effects, and lighting control.
Purchase this product and earn 175 reward points, which are tied to VIP membership program. Learn More >
We live in a colorful world, but how much do you really know about color? Your eyes may deceive you, while the sensors don’t lie. This Gravity: AS7341 11-Channel Visible Light Sensor can tell you the truth about color.
Gravity: AS7341 11-Channel Visible Light Sensor employs the new generation of AS7341 spectral sensor IC launched by the well-known AMS company. The sensor features eight channels for the visible light, one channel for near-IR, and one channel without a filter. Also, it integrates a dedicated channel to detect ambient light flicker. Besides that, this sensor comes with 6 independent 16-bit ADC channels for data processing in parallel. The two on-board extra-bright LEDs can supply light in a dark environment.
Gravity: AS7341 Visible Spectrum Sensor
RGB Color Sensor vs AS7341 Sensor
  Yellow LED
WS2812 Simulated Yellow
Recognition result of RGB color sensor
Red+Green
Red+Green
Recognition result of  AS7341 visible light sensor
Yellow
Red+Green
You can click to find information about visible light.
  • 8 optical channels covering the visible spectral range
  • 50Hz and 60Hz ambient light flicker detection
  • 6 independent 16-bit ADC channels
  • High accuracy color detection and matching
  • Color mixing effect detection
  • Lighting color temperature adjustment
  • Lighting atmosphere control
  • Modern plant cultivation
  • Power Supply: 3.3V~5V
  • Visible Light Detection Range: F1(405-425nm), F2(435-455nm), F3(470-490nm), F4(505-525nm), F5(545-565nm), F6(580-600nm), F7(620-640nm), F8(670-690nm)
  • Operating Current(LED Off): <5mA
  • LED Driving Current: Class 1-20 (4-42mA)
  • I2C Address: 0x39
  • Operating Temperature Range: -30℃~85℃
  • Operating Humidity Range: 5%RH~85%RH
  • Dimension: 22*20mm/0.87*0.79”
  • Gravity: AS7341 Visible Light Sensor x1
  • Gravity-4P I2C/UART Sensor Cable x1
    IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Projects IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Kutluhan Aktar
    Jun 28, 2022
    Vegetables and Fruits Ripeness Detection by Color w/ TensorFlow
    Projects Vegetables and Fruits Ripeness Detection by Color w/ TensorFlow
    Kutluhan Aktar
    Jul 07, 2021
    Venkatram.Nalla Nov 19, 2021
    I ordered this sensor to get light intensities at different wavelength bands.
    $17.50
