Raspberry Pi 4 Model B - 8GB with Metal Case (Dual fans)
$92.90
SKU: DFR0697-1
Purchase this product and earn 929 reward points, which are tied to VIP membership program. Learn More >
We have Raspberry Pi 4B Starter Kit that you can purchase all you need with one click.
This product includes Raspberry Pi 4 Model B - 8GB and Metal Case for Raspberry Pi 4B (Dual fans).
Here comes the 4th generation Raspberry Pi model B of popular Raspberry Pi family! Compared to the prior-generation Raspberry Pi 3 Model B+, Raspberry Pi 4B offers significantly increases in processor speed, multimedia performance, memory, and connectivity. For the end user, Raspberry Pi 4 Model B provides desktop performance comparable to entry-level x86 PC systems, which could let you enjoy smooth and high-quality experience!
Raspberry Pi 4B includes a high-performance 64-bit quad-core processor, and features dual-display support at resolutions up to 4K via a pair of micro-HDMI ports, hardware video decode at up to 4Kp60, up to 8GB of RAM, dual-band 2.4/5.0 GHz wireless LAN, Bluetooth 5.0, Gigabit Ethernet, USB 3.0, and PoE capability (via a separate PoE HAT add-on).
Overview
Overview
Peripheral Interface
Dimension
Dimension
Raspberry Pi 4B vs Raspberry Pi 3B+
Features Raspberry Pi 4B
Raspberry Pi 3B+
CPU
Broadcom BCM2711
quad-core Cortex-A72 @ 1.5GHz
Broadcom BCM2837B0
quad-core Cortex-A53 @ 1.4GHz
GPU 500 MHz VideoCore VI 400MHz VideoCore IV
Video Output 2x micro HDMI ports 1x HDMI 1.4 port
Max Resolution 4K, 60Hz1080P or 4K,30Hz
2560x1600
USB 2x USB 3.0 + USB 2.0 4x USB 2.0
Ethernet Gigabit Ethernet Gigabit Ethernet
Bluetooth Bluetooth 5.0 +BLE Bluetooth 4.2 +BLE
Power Supply Type-C (5V 3A) micro USB (5V 2.5A)
Dimension  3.5*2.3*0.76" /88*58*19.5mm 3.2*2.3*0.76" /82*56*19.5mm
Weight 46g 50g
  • Processor: Broadcom BCM2711, quad-core Cortex-A72 (ARM v8)
                            64-bit SoC @ 1.5GHz
  • Memory: 1GB, 2GB ,4GB or 8GB LPDDR4   (depending on model)
  • Connectivity: 2.4 GHz and 5.0 GHz IEEE 802.11b/g/n/ac wireless LAN,
                                Bluetooth 5.0, BLE Gigabit Ethernet
                                2 × USB 3.0 ports
                                2 × USB 2.0 ports.
  • GPIO: Standard 40-pin GPIO header
                                  (fully backwards-compatible with previous boards)
  • Video & sound: 2 × micro HDMI ports (up to 4Kp60 supported)
                                   2-lane MIPI DSI display port
                                   2-lane MIPI CSI camera port
                                   4-pole stereo audio and composite video port
  • Multimedia: H.265 (4Kp60 decode);
                              H.264 (1080p60 decode, 1080p30 encode);
                              OpenGL ES, 3.0 graphics
  • SD card support: Micro SD card slot for loading operating system and data storage
  • Input power: 5V DC via USB-C connector (minimum 3A1)
                               5V DC via GPIO header (minimum 3A1)
                               Power over Ethernet (PoE)–enabled (requires separate PoE HAT)
  • 5V 3A Power Input
Ivan.Skulkin Apr 28, 2023
Everything went very quickly
Only 5 Left
$92.90
