Protect your electronic projects from rain and water splash using this waterproof IP68 enclosure. Made from high-quality ABS material, these boxes are sturdy and terrific for use indoors and outdoors. Each box has a transparent cover with a lid gasket, and there are screws and screw decorative caps in the package. Aside from that, the “ears” on the enclosure allow you to easily fix it on other objects. This project box is suitable for LattePanda V1, Raspberry Pi, and other boards with smaller sizes.
Sep 07, 2023
The grid-insert requires a little finese - Using coarse thread standoffs, I needed to use a tool to widen the holes a bit. Other than that, I love these things!
Oct 21, 2022
Very good as description
Oct 21, 2022
