SIM7000A Arduino NB-IoT / LTE / GNSS / GPRS / GPS Expansion Shield (America)
$39.90
SKU: DFR0763
  • $39.00 3+ items
  • $38.00 5+ items
  • $37.00 10+ items
Notify me when available
NB-IoT (Narrow Band-Internet of Things) technology is a new IoT technical branch and supports cellular data network connection of low power consumption device in WAN (Wide Area Network), which also called as LPWAN. NB-IoT operates in authorized frequency spectrum. It can be directly deployed to GSM, UMTS, LTE without any interference of current networks, while the bandwidth consumption is just about 180KHz.
The SIM7000 series Arduino NB-IoT/LTE/GPRS expansion shields are wireless communication modules produced by DFRobot and the design is based on SIMCom SIM7000. This wireless communication module is designed for Arduino controllers, supporting multi-frequency LTE-FDD communication, dual-frequency GPRS/EDGE communication, NB-IoT communication. No matter prototype developments or small-batch productions, the SIM7000 expansion shield is the best solution to applications of low power consumption, low latency and meddle-throughput. Besides, with onboard GNSS (Global Navigation Satellite System), SIM7000 supports American GPS, Russian GLONASS, European Galileo, Japanese QZSS and Chinese BeiDou Navigation Satellite System. It can be widely applied to IoT applications such as long-distance control, moving tracking, long distance data uploading and shared bikes.
The SIM7000 NB-IoT/LTE/GPRS expansion shield supports both SIM card and NB-IoT card synchronously.
Product SIM7000E SIM7000A SIM7000C
Form factor 24*24*2.6 24*24*2.6 24*24*2.6
Frequency
Bands
Cat-M B3/B5/B8/B20/B28 B2/B4/B12/B13 B1/B3/B5/B8
Cat-NB B3/B5/B8/B20/B28 B2/B4/B12/B13 B1/B3/B5/B8
GSM 900/1800MHz 900/1800MHz
Temperature GNSS -40℃ ~ +85℃ optional -40℃ ~ +85℃ optional -40℃ ~ +85℃ optional
Electrical Features
Supply Voltage Range(V) 3.0~ 4.3 3.0~ 4.3 3.0~ 4.3
Power
Consumption
Power Off(uA) 7 7 7
PSM(uA) 9 9 9
Sleep(mA) 1 1 1
Idle(mA) 11 11 11
Data Transfer
Cat-M(Kbps) 300(DL)/375(UL) 300(DL)/375(UL) 300(DL)/375(UL)
Cat-NB(Kbps) 34(DL)/66(UL) 34(DL)/66(UL) 34(DL)/66(UL)
EGPRS(Kbps) 85.6(DL)/85.6(UL) 85.6(DL)/85.6(UL)
Software Features
Protocol TCP/UDP/LWM2M/COAP/MQTT/ FTP/HTTP/TLS/DTLS/NTP TCP/UDP/LWM2M/COAP/MQTT/ FTP/HTTP/TLS/DTLS/NTP TCP/UDP/LWM2M/ COAP/MQTT/FTP/ HTTP/TLS/ DTLS/NTP
FOTA
Embedded AT
Firmware Upgrade USB/FOTA USB/FOTA USB/FOTA
Interfaces
SIM Card 1.8V/3.0V 1.8V/3.0V 1.8V/3.0V
UART
USB
PCM
ADC
I2C
Certification
Regulatory
RoHS\REACH\IMDA\RCM\Telstra
\Spark\CE(RED)\GCF\Deutsche Telekom\Vodafone\RCM
RoHS\REACH\GCF\FCC
\PTCRB\AT&T\Verizon\IC
RoHS\REACH\CCC\CTA
\SRRC\Mobile\Unicom\Telecom
Carrier TELSTRA/VDF*/ORANGE*/TIM*/ GCF/Deutsche Telekom
AT&T/VERIZON/ROGERS
*/PTCRB/GCF
CMCC/CUCC/CT
Version Description: The onboard BEM280 sensor is removed from the SIM7000 series expansion shield V2.0 and later.
NOTE:
SIM7000E is commonly used with frequency bands in Europe
SIM7000A is commonly used with frequency bands in America
SIM7000C is commonly used with frequency bands in China
Please carefully check your Mobile Operator statement, and select the corresponding products.
  • Input Voltage: VIN 7~12VDC(20Vmax)
  • Model: SIM7000A
  • Dimension: 53.4 x 68.6mm/2.1 x 2.7inch
  • Weight: 46g
  • SIM7000A Arduino NB-IoT/LTE/GPRS Expansion Shield x1
  • GSM Spring Antenna x1
  • GPS Internal Antenna x1
  • Notify Me Notify me when available
