FireBeetle 2 ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips.
It supports WiFi and Bluetooth dual-mode communication and features a small size, ultra-low power consumption, on-board charging circuit, and easy-to-use interface, which can be conveniently used for smart home IoT, industrial IoT applications, and wearable devices, and so on. You can easily create your own IoT smart home system when connecting it with an IoT platform like IFTTT.
FireBeetle 2 ESP32-E supports Arduino programming and will support Scratch graphical programming and MicroPython programming very soon. We provide you with detailed online tutorials and application cases, and there are thousands of sensors with welding-free Gravity interfaces and actuators to help you get started easily. Besides, the stamp hole design makes it able to be easily embedded in your PCB, greatly saving your costs and time to build and test a prototype.
Note: FireBeetle 2 and FireBeetle pins and sizes are not compatible, and neither are the expansion boards.
Figure 2. Pinout
Espressif has recently released one wafer-level change on the ESP32 Series of products: ESP32-E. Below are the main design changes in the ESP32-E Series of chips:
1. PSRAM Cache Bug Fix: Fixed “When the CPU accesses the external SRAM in a certain sequence, read & write errors can occur”.
2. Fixed “When each CPU reads certain different address spaces simultaneously, a read error can occur.”
3. Optimized 32.768 KHz crystal oscillator stability, the issue was reported by the client that there is a low probability that under ESP32-D hardware, the 32.768 kHz crystal oscillator couldn’t start properly.
4. Fixed Fault injection issues regarding secure boot and flash encryption are fixed.
5. Improvement: Changed the minimum baud rate supported by the CAN module from 25 kHz to 12.5 kHz.
May 10, 2025
This is an amazing product
Mar 31, 2025
great board. Deep sleep ( IN THIS OLD VERSION) still 11 microA and great for my solar&battery projects. Form factor thinner than other ESP32 boards, allows to have one row of pins on each side of the mid sized breadboards. Battery management very good, solar panels working at their MPPT, battery recharged also during deep sleep periods.
Apr 09, 2024
Flashed MicroPython and found absolutely no problems so far. Do what is promised.
