FireBeetle 2 ESP32-E IoT Microcontroller (32M / 512KB, Supports Wi-Fi & Bluetooth)
$8.90
SKU: DFR0654
  • $8.60 3+ items
  • $8.50 5+ items
  • $8.30 10+ items
FireBeetle 2 ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips.
It supports WiFi and Bluetooth dual-mode communication and features a small size, ultra-low power consumption, on-board charging circuit, and easy-to-use interface, which can be conveniently used for smart home IoT, industrial IoT applications, and wearable devices, and so on. You can easily create your own IoT smart home system when connecting it with an IoT platform like IFTTT.
FireBeetle 2 ESP32-E supports Arduino programming and will support Scratch graphical programming and MicroPython programming very soon. We provide you with detailed online tutorials and application cases, and there are thousands of sensors with welding-free Gravity interfaces and actuators to help you get started easily. Besides, the stamp hole design makes it able to be easily embedded in your PCB, greatly saving your costs and time to build and test a prototype.
Note: FireBeetle 2 and FireBeetle pins and sizes are not compatible, and neither are the expansion boards.
FireBeetle 2 Board ESP32-E Board Overview (Arduino Compatible)
Figure 1. Board Overview
FireBeetle 2 Board ESP32-E IoT Microcontroller Pinout
Figure 2. Pinout
What's the difference between FireBeetle 2 ESP32-E and FireBeetle ESP32?
-ESP32-E uses a data encryption chip to protect program security
-ESP32-E is equipped with a DFRobot GDI(General Display Interface) to connect screens like DFR0664/DFR0649/DFR0665/DFR0669
-Software are ecologically compatible with both ESP32 and ESP32-E, except for minor changes in pin mapping
-ESP32-E cannot use an expansion board for ESP32 V4.0
SKU
DFR0478
DFR0654
Microcontroller
ESP32-D
ESP32-E
Power Supply Interface
Micro USB
USB-C
USB to UART
CH340C
CH340K
Operating Voltage (V)
3.3V
3.3V
Flash
16MB
4MB
SRAM (KB)
520k
520k
Analog Pins
5
5
Digital Pins
10
10
UART
1
1
I2C
1
1
SPI
1
1
Side Key
RGB_LED
DisplayPort (GDI)
Stamp Holes
Fool-proof
Silkscreen
underside
two-sided
Mount Hole Size (mm)
3.5
2
Dimension (mm)
29*58
25.4*60
Weight (g)
24 g
23g
Espressif has recently released one wafer-level change on the ESP32 Series of products: ESP32-E. Below are the main design changes in the ESP32-E Series of chips:
1. PSRAM Cache Bug Fix: Fixed “When the CPU accesses the external SRAM in a certain sequence, read & write errors can occur”.
2. Fixed “When each CPU reads certain different address spaces simultaneously, a read error can occur.”
3. Optimized 32.768 KHz crystal oscillator stability, the issue was reported by the client that there is a low probability that under ESP32-D hardware, the 32.768 kHz crystal oscillator couldn’t start properly.
4. Fixed Fault injection issues regarding secure boot and flash encryption are fixed.
5. Improvement: Changed the minimum baud rate supported by the CAN module from 25 kHz to 12.5 kHz.
  • ESP32 Dual-core low power main controller, 10uA power consumption
  • WiFi+Bluetooth 4.0 Dual-mode Module
  • GDI Display Port, easy to connect
  • Onboard Charging Circuit and PH2.0 lithium Battery Interface
  • Operating Voltage: 3.3V
  • Input Voltage: 3.3V~5.5V
  • Support Low-Power: 2mA
  • Max Discharge Current: 600mA@3.3V LDO
  • Max Charge Current: 500mA
  • Support USB Charging
  • Processor: Tensilica LX6 dual-core processor (One for high-speed connection; one for independent application development)
  • Main Frequency: 240MHz
  • SRAM: 520KB
  • Flash: 32Mbit
  • Wi-Fi Standard: FCC/CE/TELEC/KCC
  • Wi-Fi Protocol: 802.11 b/g/n/d/e/i/k/r (802.11n,speed up to 150 Mbps), A-MPDU and A-MSDU Aggregation, support 0.4us guard interval)
  • Frequency Range: 2.4~2.5 GHz
  • Bluetooth Protocol: Bluetooth v4.2 BR/EDR and BLE standard compliant
  • Bluetooth Audio: CVSD and SBC audio
  • Operating Current: 80mA(Average)
  • Support Arduino download with one-key
  • On-chip Clock: 40MHz crystal, 32.768KHz crystal
  • Digital I/O x10(Arduino default)
  • Analog Input x5(Arduino default)
  • SPI x1(Arduino Default)
  • IIC x1(Arduino Default)
  • I2S x1(Arduino Default)
  • RGB_LED: 5/D8
  • Connector: FireBeetle V2 series compatible
  • Module Size: 25.4×60mm/1×2.36”
  • Mount Hole Size: inner diameter of 2.0mm
  • FireBeetle 2 Board ESP32-E x1
  • 18pin-2.54mm Pitch Pin x1
  • 18pin-2.54mm Pitch Pin Female x1
  • 14pin-2.54mm Pitch Pin x1
  • 14pin-2.54mm Pitch Pin Female x1
RiverTrue
Jan 23, 2025
PiP-WATCH Project
Projects PiP-WATCH Project
auroraAA
Jun 06, 2024
Pet Indoor Positioning with Fermion BLE Sensor Pack
Projects Pet Indoor Positioning with Fermion BLE Sensor Pack
RoniBandini
Feb 22, 2024
DIY Smart 3D Printer Enclosure
Projects DIY Smart 3D Printer Enclosure
Mukesh Sankhla
Jan 17, 2024
Pixo | Dazzling Desk Display
Projects Pixo | Dazzling Desk Display
Mukesh Sankhla
Dec 30, 2023
Robot Arms for Accessibility
Projects Robot Arms for Accessibility
donutsorelse
Dec 05, 2023
pippo.pluto Mar 31, 2025
great board. Deep sleep ( IN THIS OLD VERSION) still 11 microA and great for my solar&battery projects. Form factor thinner than other ESP32 boards, allows to have one row of pins on each side of the mid sized breadboards. Battery management very good, solar panels working at their MPPT, battery recharged also during deep sleep periods.
Steffen.Lorenz Apr 09, 2024
Flashed MicroPython and found absolutely no problems so far. Do what is promised.
KOUBELAN RICHARD.AKPAGNI Jul 13, 2023
This is a good product. I like
