HIFI Digital Bluetooth Amplifier-50W*2
$15.90
SKU: DFR0803
  • $15.50 3+ items
  • $15.20 5+ items
  • $14.70 10+ items
Purchase this product and earn 159 reward points, which are tied to VIP membership program. Learn More >
Does sound quality matter to you? If Yes, then come to take a look at this HIFI Bluetooth Power Amplifier board! With AM interference suppression and filtering function, the board THD can be as low as 0.1% even when working for a long time at large power output, while bringing you very round and clear sound. It features 50W output power, volume adjustment knob, AUX+Bluetooth 5.0 input, dual-channel output, and DC5-27V operating voltage. This Bluetooth Power Amplifier board works well with 4~8Ω, 30W-200W passive speakers. You can connect it to Raspberry Pi, mobile phones, and other main-controllers with Bluetooth to DIY your projects.
The board comes with bottom/top protective panels and supports protection mechanisms including overvoltage, undervoltage, overheating, short circuit protection, and DC detection.
Operation Instruction
Connect the board with a speaker, power it on. Rotate the knob then the indicator led lights up. Turn on the Bluetooth of your phone or Raspberry Pi, the” BT-WUZHI” will be searched, and then click to connect it. It connects successfully with a prompt tone, and now it can play music. The Bluetooth will be reconnected automatically when the module is powered on next time.
Note:
The board will output adequate power only when the audio input and power source voltage/current are sufficient. The higher the power supply voltage, the larger the output power. Besides that, speaker impedance also changes the amplifier board power output. Please note that in the case of enough voltage and current, the larger the speaker impedance in ohms, the smaller the output power.
  • Power Supply: 5-27V
  • Input: AUX+Bluetooth 5.0
  • Audio Quality: HIFI
  • Output Power: 50W*2
  • Compatible Speaker: 30W-200W, 4Ω-8Ω
  • Channel: left/right channel (Stereo)
  • Bluetooth Transmission Distance: 15m (Without any obstacle)
  • Protection Mechanism: overvoltage, undervoltage, overheating, short circuit protection, and DC detection
  • Power Voltage:
           12V----8Ω Speaker/12W(left channel)+12W(right channel), 4Ω Speaker/20W+20W
           15V----8Ω/18W+18W,4Ω/>30W+30W
           19V----8Ω/32W+32W,4Ω/>45W+45W
           24V----8Ω/38W+38W,4Ω/>55W+55W
Projects
Review: Review to 502C 50+50W Class D Amplifier
Introduction: This is Wuzhi Hi-Fi class D amplifier which can output a maximum of 100 watts. This works on a voltage under 24 volts and has a stable output.
  • HIFI Digital Bluetooth Amplifier-50W*2 x1
  • Acrylic Protective Case x2
  • Screwdriver x1
  • 20cm Power Wire x1
  • Knob x1
  • Heat Sink x1
  • Accessories Package x1
  • Only 8 Left
