USB GPS Receiver (Compatible with Raspberry Pi/ LattePanda/ Jetson Nano)
$13.10
SKU: TEL0137
  • $12.70 3+ items
  • $12.50 5+ items
  • $12.00 10+ items
Compact and lightweight GPS receiver with high precision positioning, USB interface, and built-in battery for quick start. Suitable for various devices and uses.
Purchase this product and earn 131 reward points, which are tied to VIP membership program. Learn More >
This GPS receiver brings much more accurate and faster positioning performance with stronger signal compared with traditional GPS receivers. It is compact, lightweight and portable. Integrated with built-in receiving antenna, this product adopts a high-precision positioning chip and industrial-grade manufacturing process so that it can meet the positioning requirements of both industrial-grade and personal use. The GPS receiver has battery inside for supplying power for storing satellite data, such as satellite signal status, final position and time that would greatly increase the positioning speed at the module’s next boot. In addition, this receiver adopts USB interface, which can be conveniently used in maincontrollers like Raspberry Pi, NVIDIA, LattePanda. It is suitable for vehicle navigation, handheld positioning, wearable devices and other fields.
USB GPS Receiver
Dimension
  • Chip: UBX-G7020-KT
  • Frequency: L1, 1575.42MHz/L2,1561.10MHZ/L3,1602.00MHZ
  • Baud Rate: 4800,9600,19200,38400,57600,115200bps
  • Receiving Channel: 56CH
  • Sensitivity: tracking -162dBm; Acquisition: 160dBm; cold start: -148dBm
  • Cold Start: 29s average
  • Warm Start: 3s average
  • Hot Start: 1s average
  • Accuracy: horizontal position accuracy<2.5M, SBAS<2.0M
                          Timing Accuracy: 30ns
  • Update Rate: 1Hz
  • Outline Dimension: 60×24×9mm
  • Weight: 50g
  • Operating Temperature: -40℃~85℃
  • Storage Temperature: -40℃~85℃
  • USB GPS Receiver x1
    LattePanda Alpha Projects Overview
    Blog LattePanda Alpha Projects Overview
    May 30, 2022
    Only 10 Left
