Raspberry Pi Compute Module 4 IoT Router Carrier Board Mini
$25.00 $45.00
SKU: DFR0767
The IoT Router Carrier Board Mini expands Raspberry Pi CM4 with dual gigabit ports via PCle, USB2.0, OpenWRT support, GPIO, and a compact 55x62mm size.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
Compute Module 4 IoT Router Carrier Board Mini is an internet expansion board based on the Raspberry Pi Compute Module 4. When connecting with a gigabit network card via PCle, it brings Raspberry Pi CM4 two full-speed gigabit network ports and offers better performance, lower CPU usage, and higher stability for a long time work compared with a USB network card. Besides, with a mini size of 55 x62mm, the board still retains the characteristic GPIO pin header of Raspberry Pi, which makes it applicable for connecting other actuators, sensors, and smart cooling fan. Furthermore, there is also a USB2.0 interface that can be connected to mobile hard drives, printers, WIFI modules, LTF modules, etc.
Compute Module 4 IoT Router Carrier Board Mini now provides OpenWRT open-source router system. After a simple setup, it can be used as a router. It is also compatible with Raspberry OS, Ubuntu Server and other Raspberry Pi systems.
The powerful performance of BCM2711 4 core 1.5GHz Cortex-A72 and the rich software support in the Raspberry Pi community make this board a solid foundation for building high-performance gateways, smart routers, and home IoT platforms. It can also be connected to peripherals and used as a mini-NAS, wireless network bridge, or LTE Internet terminal.
The board-socket of CM4 is fragile, please align the direction and then press it down. It is recommended not to repeatedly plug and unplug the CM4 module.
Make sure the CM4 installation direction is correct before powering up.
Connect Diagram
Dimension
Note: The CM4 Compute Module is not included.
  • Compatible Module: Raspberry Pi Compute Module 4 series
  • Ethernet:
            ETH1: Compute Module 4 Built-In
            ETH2: PCI Express 1000BASE-T NIC
  • USB:
            1x USB-C: Power only
            1x USB-C: USB 2.0 High Speed
  • Storage Card: microSD slot (Only modules without eMMC supported)
  • GPIO: 26Pin GPIO compatible with Raspberry Pi
  • Power Supply: USB-C 5V/3A
  • Operating Temperature: 0℃~80℃
  • Dimension: 55x62mm/2.17x2.44”
  • Compute Module 4 IoT Router Carrier Board Mini x1
    2022 Top 10 Bestselling Products
    Blog 2022 Top 10 Bestselling Products
    Jan 11, 2023
    E.Shattow Aug 03, 2024
    Fit and function are great with the Milk-V Mars CM Lite and Arace Heatsink 5540A for Radxa CM and Milk-V CM. A small spacer is needed between the DFRobot IoT Router Mini on each corner fastener of the Heatsink 5540A, about the height of two credit cards. The MSEL-DIP nRPIBOOT setting is functional for selecting between the Mars CM Lite boot modes of SPI NOR flash or UART loader; The EEPROM write protect setting does not appear to be useful for the Mars CM Lite, but this is easily accessed by the test pads of that particular module even while mounted on the DFRobot IoT Router Mini. Value for money is good at the $25usd sale price.
    Tyson.Merten Nov 03, 2021
    I love this carrier board. It's the best one on the market, period. Not even a single issue in 3 months. Up the entire time.
