ESP32-S2-SOLO Wi-Fi Module (4MB Flash, 240MHz, PCB Antenna)
$2.60
SKU: DFR0743-SOLO
Purchase this product and earn 26 reward points, which are tied to VIP membership program. Learn More >
Upgrade IoT projects with the ultra-compact ESP32-S2-SOLO Wi-Fi module, combining high performance (240MHz CPU) and low-power efficiency in a tiny 18×25.5mm footprint. Featuring 4MB flash, USB OTG, and 43 GPIOs, this module is engineered for wearables, smart home devices, and industrial automation—delivering reliable connectivity without compromising space or energy.
High-Speed, Low-Power Processing
Powered by a 240MHz Xtensa LX7 core with dynamic voltage scaling, the module balances performance and efficiency. The ULP coprocessor monitors sensors during sleep mode, extending battery life for wireless applications.
Robust Connectivity & Versatility
Supports Wi-Fi 802.11 b/g/n (150Mbps) and includes USB OTG, SPI, I2C, and touch sensor interfaces. The PCB antenna ensures stable signal transmission while saving space vs. external antennas.
Developer-Ready Design
Pre-loaded with 4MB SPI flash and RoHS/CE/FCC certifications, the module simplifies prototyping. Note: Requires peripheral soldering for full functionality—optimized for engineers and advanced makers.
Note: This module is recommended for developers currently. The peripheral circuit needs to be soldered when using, and few peripheral interfaces may not perform the full functionality of the sample code. There are still bugs that have to be found and fixed.
MCU
  • Built-in ESP32-S2 chip, Xtensa® single-core 32bit LX7 microcontroller, up to 240MHz
  • Support multiple low-power modes: fine-grained clock gating, dynamic voltage and frequency scaling
  • Security: eFuse, Secure Boot, Flash Encryption, Digital Signature, Integrated AES, SHA and RSA algorithms
  • 128 KB ROM
  • 320 KB SRAM
  • 16 KB RTC SRAM
  • WiFi
  • 802.11 b/g/n
  • Data rate up to 150Mbps
  • TX/RX A-MPDU, RX A-MSDU
  • 0.4µs guard interval
  • Center frequency range of operating channel: 2412 ~ 2484 MHz
  • Hardware
  • Port: GPIO, SPI, UART, I2C, I2S, LCD interface, Camera interface, IR, pulse counter, LED, PWM, USB1.1, ADC, DAC, capacitive touch sensor, temperature sensor
  • 40 MHz Oscillator
  • 4 MB SPI Flash
  • Operating Voltage/Power Voltage: 3.0 ~ 3.6 V
  • Suggested Operating Temperature: –40 ~ 85 °C
  • Package Size: (18 x 25.5 x 3.1) mm
  • Certification
  • RoHS/REACH
  • RF Certification: FCC/CE-RED/SRRC
  • Test
  • HTOL/HTSL/uHAST/TCT/ESD
  • ESP32-S2- SOLO Wi-Fi Module (PCB antenna) x1
  • ESP32-S2-SOLO Wi-Fi Module (4MB Flash, 240MHz, PCB Antenna)
