The ESP32-S2-WROOM Wi-Fi Module combines high performance (240MHz CPU) with ultra-low power consumption, making it perfect for industrial IoT, smart home devices, and battery-powered applications. With 4MB flash, USB OTG, and built-in touch sensors, it simplifies prototyping while meeting FCC/CE compliance.
High-Speed 240MHz CPU with 4MB Flash
Powered by the Xtensa® LX7 core, the module handles complex tasks like real-time data processing and edge AI inference, while 4MB flash ensures ample storage for firmware.
Ultra-Low Power Modes for Battery Efficiency
Dynamic voltage scaling and RTC sleep modes extend battery life in wireless sensors and portable devices, with wake-up via touch sensors or threshold triggers.
Rich Peripherals: USB OTG, Touch, LCD & Camera
43 GPIOs support SPI, I2C, UART, PWM, and LCD/camera interfaces, while USB OTG enables direct host/device communication without extra chips.
Industrial-Grade Reliability
Operates reliably in -40°C to 85°C environments with FCC/CE/SRRC certifications, ideal for harsh conditions and mass production.
Note: This module is recommended for developers currently. The peripheral circuit needs to be soldered when using, and few peripheral interfaces may not perform the full functionality of the sample code. There are still bugs that have to be found and fixed.
