Fanless Intel Atom N270 with Onboard 12v DC Mainboards (Discontinued)
SKU: DFR0020
Discontinued
Note: Fanless Intel Atom N270 with Onboard 12v DC Mainboards is discontinued now.
Robots are getting more and more complex, they often require additional of multimedia, network communications, and image processing capabilities. The traditional PC system eats a lot of power which is critical for most battery operated mobile robots. This mini270 IPC has low power consumption chipset, the whole power consumption of the system only has 12W which is really great. It comes with a beautiful black aluminum alloy chassis.
It comes with a fully assembly system with 16G SSD harddisk  and 802.11 b/g wifi capability. The 16G SSD hardisk gives a great benefit for mobile robot application.
It supports both windows and Linux system, most robot software can run on this platform. It is the recommended high end controller for our HCR, 4WD mobile robot platform.
Specifications
CPU Intel Atom N270 1.6GHz, 512kbyte L2
Chipset Intel 945GSE+ICH7-M
Memory 1 * DDR2 677/533MHz of memory up to 2GB (Note Book DDR2)
Graphics Intel Graphics Media Accelerator 950, support DirectX 9.0
Audio ALC655  2 / 4 / 5.1sound channel
LAN 2* Realtek 8111C,10/100/1000M (ITX M4S2GA 1*1000M LAN)
Storage Interface 1*40 pin IDE,
1* 44 pin MINI IDE
2*SATA
Onboard Flash 1/2G (Optional)
Expansion Slots 1*PCI
1*MINI PCI-E
1*CF card Dimm
USB 7*USB 2.0(4 pcs on the back panel,3 pcs via the USB brackets connected to the internal USB headers)
Internal
I/O Connectors
1 x 24-pin ATX power connector
1 x 4-pin power connector
2 x IDE connectors
2 x SATA connectors
1 x CPU fan header
1 x system fan header
1 x front panel header
1 x Audio header
2 x USB 2.0 headers
1 x Clear CMOS Header
4 x COM Header
1 x LPT Header
1 x IR Red-way Header
1 x VGA_H Header
1 x HD_TV Header
1 x 18bit LVDS Header
Back Panel
Connectors
1*PS/2 keyboard port
1*PS/2 mouse port
1*VGA port
1*Pinter (LPT) port
2* RJ-45 LAN ports
4* USB2.0ports
2*Audio Jacks
1*S-Video(TV-OUT) port
1*12V DC Power supply port
I/O Controller 2*ITE8712F-S
BIOS AMI Authorized 8Mbit BIOS, support RPL/PXE non-disk system
Form Factor  Mini ITX 170mmx170mm
Work Environment
Work Temperature 0~60°C
Work Humidity 10%~80% relative humidity, non-condensing
Apply Range  ATM, Kiosk, Digital Signage, and Living Room PC etc.
