Gravity: I2C 1Kg Weight Sensor Kit - HX711
$24.90
SKU: KIT0176
  • $24.00 3+ items
  • $23.80 5+ items
  • $23.00 10+ items
The weight sensor is a practical sensor close to daily life scenes. It can make many interesting applications by acquiring the weight information of objects, such as household electronic scales, daily necessities weighing, daily necessities remaining alarm,and Internet of Things weighing platforms.
This weight sensor kit is equipped with all the accessories needed to build the scale, which reduces the difficulty of structure construction so that anyone can quickly create an electronic scale to obtain the weight information of the object. In addition, because everyone has different installation methods and usage habits, the sensor needs to be calibrated. The traditional method is to use a separate calibration code to obtain the calibration value. To optimize this problem, the signal adapter board in this kit is built-in The calibration algorithm can calibrate the weight information with one key, and there is no need to run a separate code for calibration.
Weight Sensor Selection Guide
Product Name
Gravity: Digital Weight Sensor
Gravity: I2CWeight Sensor
SKU
SEN0160
KIT0176
Communication Method
Dual digital/analog
I2C
Operating Voltage
5V
3.3V-5V
Optional range
1Kg
1Kg
Built-in calibration algorithm
One-key calibration
Compatibility
Arduino
Arduinomicro:bitESP32Raspberry Pi
PCB Size
38*34mm
37*31mm
Direct communication with HX711, suitable for projects that need to directly control HX711
Obtain HX711 data and process it through the onboard MCU, which is easier to use, more powerful, and compatible with more motherboards
  • Complete accessories, convenient and quick to build the scale
  • Built-in calibration algorithm
  • Weight calibration can be done by pressing the button
  • Weight calibration can be done through API
  • Gravity I2C communication mode, compatible with 3.3V and 5V
  • Compatible with Arduino series, micro:bit, ESP32, Raspberry Pi
  • Simple electronic scale
  • Daily necessities weighing
  • Daily necessities remaining alarm
  • Internet of Things weighing platforms
  • Measuring Range: 1g-1000g
  • Working Voltage: 3.3V/5V
  • Working Current: <20mA
  • AD Conversion Chip: HX711
  • Synthesis Deviation: <±0.2% g
  • Overall Dimensions after Assembly: L x W x H: 120 x 100 x 30 mm/ 4.72 x 3.94 x 1.18 inch
  • Signal Transfer Board Size: 31 x 37mm / 1.22 x 1.46 inch
  • Communication Method: I2C
  • I2C Address: 0 x 64 / 0 x 65 / 0 x 66 / 0 x 67
  • Weight sensor x1
  • Signal transfer board x1
  • Acrylic bracket x1
  • M4x20 CM screws x2
  • M5x20 CM screws x2
  • M3x8 screws and nuts x2
  • Trapezoidal feet x4
  • Gravity-4P I2C cable x1
    Unihiker Scale using Gravity HX711 i2c Pressure Sensor
    Projects Unihiker Scale using Gravity HX711 i2c Pressure Sensor
    CosmicBee
    Jul 09, 2024
    IoT AI-driven Yogurt Processing & Texture Prediction w/ Blynk
    Projects IoT AI-driven Yogurt Processing & Texture Prediction w/ Blynk
    Kutluhan Aktar
    Dec 16, 2022
    IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Projects IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Kutluhan Aktar
    Jun 28, 2022
    $19.90
