This 2 USB buck fast-charging module integrates the common 5V charging recognition function, which is compatible with 99% of the mobile phones on the market. Compared with products without charging recognition function, this module can save a lot charging time by triggering the peak current via fast charging protocol. It features 6~32V input and 3~12V output(default 5V). The voltage can be changed through fast-charging decoy. Multiple fast-charging protocols are supported and the 2 channels work independently.
With steady output, this Fast Charge Module is able to work for a long time without voltage shift. It can be suitable for projects like mobile phone fast charging, Car charging retrofit, solar charger, DIY power source, etc.
Support DCP protocol, BC1.2, Apple, Samsung protocol
Support Huawei fast charge protocol FCP/SCP, AFC
Support Spreadtrum fast charge protocol SFCP
Support Qualcomm QC2.0 and 3.0
Support MTKPE1.1/PE2.0
