A real-time clock module uses the DS3231 chip for high accuracy, supports battery input, has alarms, and operates in 24/12-hour formats. Batteries not included.
Purchase this product and earn 89 reward points, which are tied to VIP membership program.
Learn More >
This real-time clock module (RTC) uses the DS3231 chip that integrates a crystal resonator and a temperature compensator, which improves the long-term accuracy of the module. In the range of -40°C to +85°C, the accuracy of DS3231 remains at ±3.5ppm (±0.3024 seconds/day).
The device incorporates a battery input, and maintains high precision timing when main power to the device is interrupted. The RTC provides information of seconds, minutes, hours, week, day, month and year, and it can automatically adjust the date at the end of the month, including corrections for leap year. The clock operates in either the 24-hour or 12-hour format with AM/PM indicator. Two programmable time-of-day alarms and a programmable square-wave output are provided. In addition, the RST pin can be used as a push-button input for microprocessor reset.
NOTE: Due to the latest air cargo regulations, the transport audit of special items such as batteries, magnets and liquids will become very strict, so this RTC module does not come with batteries anymore, please buy them locally. The button cell battery model that goes with the module is CR1220.
A real-time clock (RTC) module with integrated MEMS resonator, reducing the risk of mechanical failure, suitable for scenarios with strong and frequent vibration.
A real-time clock (RTC) module with integrated crystal oscillator, featuring higher precision and lower power consumption, suitable for scenarios requiring high precision and low power.
A real-time clock (RTC) module with integrated crystal oscillator, featuring built-in 236Byte SRAM storage, capable of storing data with ultra-low power consumption, suitable for low-power loT applications requiring real-time clock.
A cost-effective RTC module with integrated crystal oscillator, featuring built-in 70Byte SRAM storage, capable of storing data with ultra-low power consumption, suitable for low-power loT applications requiring real-time clock.
Add to Cart
Internal integrated crystal resonator, small deviation
Internal integrated temperature compensator, small temperature drift
