M.2 (A+E Key) AX210 WiFi 6E Network Card for for LattePanda Sigma, Alpha, Delta
$32.90
SKU: FIT0822
  • $32.00 3+ items
  • $31.00 5+ items
  • $30.00 10+ items
Purchase this product and earn 329 reward points, which are tied to VIP membership program. Learn More >
This Intel AX210NGW network card takes you into the Wi-Fi 6 era!Adopting the upcoming Wi-Fi 6E standard, the network card provides three-band (2.4GHz, 5GHz, and 6GHz) signals, and extends Wi-Fi to 6GHz, up to 5374Mbps (2400 Mbps@6GHz+2400 Mbps@5GHz+574 Mbps@2.4GHz) transmission rate, which allows you to experience smooth 4K HD-video streaming and online gaming in today’s dense and congested environments.
The network card has been upgraded to Bluetooth 5.2, which is downward compatible with Bluetooth 5.1/5.0/4.2/4.0. Bluetooth 5.2 includes an isochronous channel feature that lays the foundation for the implementation of the next generation of Bluetooth Audio–Low Energy Audio. Bluetooth 5.2 provides a 4x range on the basis of Bluetooth 4.2, which doubles the transmission speed, thereby reducing the total power.
It supports MU-MIMO technology, when multiple users send and receive data at the same time, multiple MIMO effectively improves the signal gain. Transmission from 80MHz to 160MHz, dual throughput, ultra-low latency, and uninterrupted connection, multiple devices can be connected to the Internet at the same time without queuing.
The security of web browsing is guaranteed. Advanced WPA 3 encryption is used during the browsing process, which is compatible with WPA 2, WEP encryption, preventing network intrusions from hackers and malicious software.
Note:
1. The network card interface is M.2 (A+E Key). Please confirm whether your device interface matches this product before use. If not, you need an M.2 connector.
2. Only Windows 10 64-bit is recommended. If you cannot install the driver, you need to update the latest version of Windows 10
3. A WIFI 6E router is required to realize the 6GHz frequency band.
4. You need to download the AX210NGW driver from the Intel website.
  • Network Card Chip: AX210NGW
  • Interface Type: NGFF (M.2)
  • Protocol Frequency Band: 802.11ax/ac/a/b/g/n
  • Built-in Functions: Bluetooth 5.2, MU-MIMO
  • Transmission Rate: 2.4G-574M / 5G-2400M/6G-2400M
  • Support System: Windows10 64-bit
  • Size: 22mm*30mm / 0.87*1.18 inch
  • M.2 (A+E Key) AX210 WiFi 6E Network Card x1
  • Antenna x2
  • M.2 (A+E Key) AX210 WiFi 6E Network Card for for LattePanda Sigma, Alpha, Delta
    $29.90
