Gravity: Digital Magnetic Sensor
$2.90
SKU: DFR0033
  • $2.85 2+ items
  • $2.75 5+ items
  • $2.50 10+ items
Detect nearby magnetic objects with this digital magnetic sensor, offering a 3.3V-5V range, easy interfaces, high quality connector, and compact size.
what's the best way to detect the magnet? Use anther magnet. But it's not sensitive enough. You have to feel it by youself.Right. This magnetic sensor knows whether there is a magnetic object nearby or not. And it correctly tells you through ditigal output.See below picture for a quick demo!
Gravity: Digital Magnetic Sensor Detection
Gravity: Digital Magnetic Sensor Detection Successful
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm mounting holes)
  • High quality connector
  • Immersion gold surface
  • Supply Voltage: 3.3V to 5V
  • Indicator LED on board
  • Interface: Digital
  • Size:22x30mm (0.9x1.2in)
  • Digital magnetic sensor   x1
  • Digital cable   x1
Sam . Jan 17, 2023
I love these, make it so easy for knowing the status of a door being open or closed.
Ohsoo. Feb 24, 2021
Out Of Stock
$2.90
