RS485 Wind Vane Direction Sensor
$45.00
SKU: SEN0482
  • $44.00 3+ items
  • $43.00 5+ items
  • $41.40 10+ items
Purchase this product and earn 450 reward points, which are tied to VIP membership program. Learn More >
The wind direction sensor (also known as wind vane) is a professional meteorological instrument used to measure horizontal wind direction. It integrates a hall sensor inside. The shell and weather vane are made of aluminum alloy material and use special mold precision die casting process, featuring small dimension tolerance and high surface accuracy. The sensor internal circuit is protected, which makes the sensor have the properties of high strength, weather resistance, anti-corrosion, and waterproof. The cable connector adopts corrosion-resistant military plug that ensures the long service life of the product.
A low-inertia wind direction sensor is used to sense the wind direction. When the wind direction changes, the tail wing rotates to drive the axle magnet to rotate through the shaft, thereby obtaining accurate wind direction information. It can detect the 16 natural wind directions. This sensor with high cost performance can be widely used in meteorology, ocean, environment, airports, ports, laboratories, industry, agriculture and transportation.
How does a wind vane work?
1. Wind Vane: The nose of the vane always points into the wind direction. This is because the wind applies a force on the flat surface of the vane, causing it to rotate until it aligns with the wind direction.
2. Signal Conversion: Attached to the vane is either a potentiometer or a magnetic sensor. This device converts the rotational movement of the vane into an electrical signal.
3. Signal Processing: The electrical signal is then processed to determine the wind direction.
Connection Diagram of RS485 Wind Direction Sensor, RS485 to UART Signal Adapter Module and Arduino Uno
Dimension Diagram of RS485 Wind Vane
  • High measurement accuracy, fast response, and good interchangeability
  • Easy to install and operate
  • High sensitivity: start-up wind speed ≤ 0.3m/s
  • Suitable for various harsh environments, strong wind resistance
  • Measuring Range: 16 directions & wind direction of 360°
  • Start-up Wind Speed: 0.3m/s
  • Lead Length: 2.5m/8.20"
  • Power Voltage: 7-24V
  • Communication Protocol: RS485 interface Modbus protocol
  • RS485 Wind Direction Transmitter x1
  • 2.5m Wire x1
    How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Projects How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Meimei
    Jul 01, 2023
    Hex.Hobby Jan 22, 2025
    has rugged construction suitable to withstand harsh environmental conditions. One of best Wind direction Sensor
    Only 9 Left
