USB Dual Band WiFi Network Card (Compatible with Jetson Nano&LattePanda)
$14.00
SKU: TEL0145
  • $13.60 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
Purchase this product and earn 140 reward points, which are tied to VIP membership program. Learn More >
Does it still bother you that you cannot access the Internet anytime anywhere? Here comes a convenient dual-band wireless network card, play-and-play. Bring you a very fast and stable wireless network!
Based on IEEE 802.11n advanced wireless network protocol, this network card offers up to 400Mbps transmission rate and more efficient data transmission in LAN. It provides 64/128/256-bit WEP data encryption and WPA/WPA-PSK, WPA2/WPA2-PSK security mechanism, which greatly improves the security of data transmission. Besides that, the WiFi module adopts CAA technology to detect signal interference. When there is wireless signal interference around, the bandwidth mode will be adjusted automatically to avoid interference so as to enhance the stability of the wireless network. With the function of the soft router, the wireless card can be used as a router to distribute the network to smartphone and tablet PC. Even the intelligent antenna has been integrated into an ultra-compact body, the module can still provide excellent signal receiving ability and steady wireless signal. After inserting the USB port, only less than 2cm volume is exposed, which almost does not take up any space.
This product is not only suitable for various communication devices that are currently widely used, such as mobile phones, tablet PCs, and desktops, etc.; but also, for various mini-PCs for driver-free use, such as Raspberry Pi, Jetson Nano, PYNQ-Z2 development board, etc.
  • Chip: RTL8811CU
  • Interface: USB 2.0
  • Protocols & Standards: IEEE802.11/b/g & 802.11n & 802.11ac (1T1R mode)
  • Working Frequency Band: 2.412GHz—2.4835GHz, 5.15 GHz—5.825 GHz
  • Antenna: Built-in dual-band antenna
  • Security Encryption Method: WFA, WPA, WPA2, WPS2.0, WAPI
  • Operating Voltage: 5.0VDC± 5%
  • Power Consumption: <1W
  • Size: 33*16*7mm/1.30*0.63*0.28”
  • Net Weight: 3.4g
  • USB Dual Band WiFi Network Card x1
  • USB Dual Band WiFi Network Card (Compatible with Jetson Nano&LattePanda)
