Note: Xia mi Multi-functional Expansion Board only compatible with micro:bit V2, not compatible with micro:bit V1 board.
Look for more hardware to play with your new micro:bit? Check this out! This is a micro:bit V2-based multi-functional expansion board for programming education.
Featuring a small size of 57*87mm and a compact layout, the board expands more than 10 functional modules including sensors of all kinds, 4-way motor, LED lights, OLED screen, and external power supply, which allows students to not only learn the basic functions of micro:bit but also further advance to the next level like controlling robot cars, Mecanum wheel robot, and so on. Moreover, even with so many things integrated on the board, the price still remains low. Come and explore all these extra features!
Board Overview
Tutorial- MakeCode
Enter the MakeCode programming platform in browser: https://makecode.microbit.org/
Create a new project and name it.
Load in the program library of xia_mi board: click “setting”, and “expansion” in turn, then paste this link in the search box: https://github.com/DFRobot/pxt-DFRobot_xia_mi_Board.
1. Light Up RGB LED
2. Traffic Signal Light
3. Ambient Temperature and Humidity Sensor
4. Control Servo via Angular Rotation Sensor
5. IR-controlled Relay Switch
6. Fire Alarm
7. SR04 Ultrasonic Distance Sensor
8. 4-way Motor Drive
