This is an industrial-grade USB to RS485 module with a DC voltage output of up to 36V, which is applicable to industrial instruments that require a high-voltage power supply.
The converter can be directly powered by the USB bus, no external power supply required.
With strong compatibility, this USB to RS485 converter conforms to the USB 2.0 standard (downward compatible) and the RS485 standard, and supports Systems like Windows 98/ME/2000/XP/7/8/10/Vista, Mac and so on.
The module comes with built-in 15KV ESD protection and a maximum of 600W lightning surge protection. In terms of over-current and over-voltage protection, it adopts self-recovery fuse + TVS protection circuit to effectively extend the service life of the module.
Featuring plug-and-play and hot-swappable, the USB to RS485 module has onboard indicators for visually displaying Rx/Tx communication status. It offers adaptive data communication rate from 300 to 921.6kbps.
