This DB9 Female to RJ45 Female Adapter can be used to handle serial data communication between RS232 devices with one RJ45 network cable, or as an extender to extend RS232 serial signal to about 20m.
Two modules are required for serial port to network cable transmission. It enables to extend serial signal to 20m with CAT5/6 network cable and supports 720P/1080P/1080P analog HD formats.
The nickel-plated connector provides excellent anti-oxidation, more sensitive contact and stable signal transmission performance. The shell employs durable PVC material for better extending service life.
These modules are compatible with all kinds of computers, laptops, printers, modems, routers, PDA, POS, numerical control machine, Barcode scanner, etc. No need to install drive, plug and play, simple and fast.
