BOSON Science Starter Pack
$35.00
SKU: TOY0084-lite
Purchase this product and earn 350 reward points, which are tied to VIP membership program. Learn More >
BOSON Science Starter Pack is a set of digitalized scientific exploration tools for young scientists to build their hands-on STEM lab.
BOSON science starter pack brings kids:
2 scientific sensors for data collection.
8 scientific explorations across three different fields.
Plug-and-play LED monitor for instant result display.
Splitter module facilitates the transition from non-coding to micro:bit extension.
Unlike traditional scientific experiments, the BOSON Science Kit can provide precise data support and display sensor readings in real-time, supporting instant data observation and recording. Furthermore, all electronic modules can be freely combined and reused, making it convenient to explore various experimental ideas or integrate them with micro:bit for further data analysis and hardware control.
We have prepared eight detailed tutorials enabling science observations in Physical Science, Earth & Space Science, and Life Science. These tutorials also cover the usage with micro:bit as an expansion, facilitating the transition for students from coding-free to programming learning.
You can explore "Do plants grow better with more water?" using the BOSON Soil Moisture Sensor.
In the tutorial "Are we able to ‘see’ conductivity?" you will investigate how different materials and states of matter have different abilities to carry positive and negative charges.
We often see the moon shining in the dark sky. The moon itself does not produce any light of its own, but why does it seem bright at night? And if we observe it carefully enough, we can find that the moon is not uniformly bright and there are dark shades all over it. Why is that? Following tutorial Why Does the Moon Shine at Night? to find out.
With the help of the BOSON splitter module, the output signal is divided into two branches: one links to the OLED display for immediate data display, and the other links to the micro:bit for additional processing.
Shop Packages:
1. If you want to observe data from basic scientific experiments.
2. If you want to conduct data analysis or learn programming and hardware control.
Add to cart: BBC micro:bit board V2.0 for STEM Education - DFRobot
Add to cart: micro:bit Expansion Board for Boson - DFRobot
More Tutorials:
BOSON Science Starter Pack Tutorial - DFRobot Education- online resources for STEM and maker education
BOSON Science Starter Pack Tutorials
  • Plug and play
  • Easy setting up
  • Can be used repetitively
  • STEM Education
  • Science Class
    • Operating Voltage: 4.5V-5.5V
    • Dimension: 50 x 130 x 170 (mm)
    • Weight: 300g
  • Soil Moisture Sensor x1
  • Light Sensor x1
  • OLED Module x1
  • Mainboard-1IO x1
  • Splitter Module x1
  • 3xAAA Battery Holder x1
  • Cable 10cm x4
  • Cable 20cm x2
  • Package Box x1
    Course BOSON Science Starter Pack Tutorial
    Nov 27, 2024
    A Science Experiment: Conductivity of Salt Solution with micro:bit
    Projects A Science Experiment: Conductivity of Salt Solution with micro:bit
    qianqian.xua
    Feb 04, 2024
    Build and Test Earthquake Proof Buildings with BOSON and micro:bit
    Projects Build and Test Earthquake Proof Buildings with BOSON and micro:bit
    Danli
    Jun 26, 2023
