RJ45 Terminal Block Adapter - Vertical
$11.90
SKU: FIT0851
  • $11.70 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
DIN Rail RJ45 Terminal Block Adapter simplifies wiring with an RJ45 jack and eight-port terminal blocks. Ideal for sensors, displays, micro-controllers.
This DIN Rail RJ45 Terminal Block Adapter-Vertical, perfect for simplifying complex wiring, consists of an RJ45 Ethernet jack and an eight-port terminal.
You can connect an RJ45 Ethernet to PCB which can be DIN rail-mounted, easy to use. Then, all 8 wires are broken out into terminal blocks, so without soldering, you can connect and power your sensors, displays, micro-controllers, etc.
  • Simplifying complex wiring
  • Easy to use
  • Connect sensor
  • Power display
  • Connect micro-controllers
  • Color: Green
  • Interface: RJ45 eight-core interface
  • Material: PVC environment-friendly shell
  • Installation: DIN rail-mounted
  • Dimension: 90*35*53mm/ 3.54*1.38*2.09”
  • RJ45 Terminal Block Adapter - Vertical x1
  • Only 4 Left
