This DIN Rail RJ45 Terminal Block Adapter-Vertical, perfect for simplifying complex wiring, consists of an RJ45 Ethernet jack and an eight-port terminal.
You can connect an RJ45 Ethernet to PCB which can be DIN rail-mounted, easy to use. Then, all 8 wires are broken out into terminal blocks, so without soldering, you can connect and power your sensors, displays, micro-controllers, etc.
