Note: You need to use the bare network cable plug to plug in and out, and the press type will be blocked.
This DIN Rail RJ45 Terminal Block Adapter-Horizontal, perfect for simplifying complex wiring, consists of an RJ45 Ethernet jack and an eight-port terminal.
You can connect an RJ45 Ethernet to PCB which can be DIN rail-mounted, easy to use. Then, all 8 wires are broken out into terminal blocks, so without soldering, you can connect and power your sensors, displays, microcontrollers, etc.
