10 I/Os Relay Module - CPU ESP32 (Relay Output)
$219.00
SKU: DFR0901
The ESP32 industrial controller enables easy monitoring and control of machines with RS485, Ethernet, and optically isolated inputs, suitable for HVAC and motor control.
Purchase this product and earn 2190 reward points, which are tied to VIP membership program. Learn More >
The ESP32 devkit industrial controller (relay output) is an easy-to-install and configure industrial expansion module that is extremely flexible due to its open-source hardware. It's user-friendly and easy to get started with. It uses the ESP32 devkit as the core controller, providing a simple, low-cost industrial control solution with standard PLC interfaces, supporting RS485, Ethernet, and optically isolated inputs. It can be used to monitor and control your machines, such as alarms, elevator control, production lines, etc. The most typical applications include the control of fans, pumps, air conditioners, AC and DC motors, and complete HVAC solutions.
Interfaces of 10 I/Os Relay Module - CPU ESP32 (Relay Output)
  • Control and automation of machines
  • Control of AC and DC motors
  • MCU: ESP32 devkit
  • Power Input: 12-24V DC
  • Input Rated Voltage: 24V DC
  • Max Current: 1.5A
  • Clock Speed: External 240 MHz; Internal 8MHz
  • Flash: 4MB
  • SRAM: 4MB
  • PSRAM: 2MB
  • Communication: USB-RS485-ETH-WiFi-BLE
  • Operating Voltage Range: 12~24V DC
  • Power Consumption: 30W MAX
  • Digital Input: 0-3.3-24V DC(10Hz)
  • Digital Isolated Relay Output: 5-24V DC
  • Operating Temperature: -20℃~60℃
  • Operating Humidity: 10%~90%
  • Storage Temperature: -20℃~60℃
  • 10 I/Os Relay Module - CPU ESP32 (Relay Output) x1
  • Only 6 Left
